steely's Avatar
'87 3.2 rear drop link torque, 61 or 66 ft lb?
Bentley shows the torque on one page as 61 ft-lb (85 Nm) and on another as 66 ft-lb (90 Nm) for the M12 bolts for the rear sway drop links.
Can someone set me straight (and/or do 5 ft-lbs matter)?
Thanks,
Dan
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-22-2011, 02:35 PM
steely's Avatar
bump - for the morning?
Dan
Venetian Blue
Old 11-22-2011, 10:10 PM
KNS KNS is online now
I would go with 61 which still seems a bit high, the bolt isn't that big.
On a related note, I had a clunking coming from underneath the car (only on right turns) a few years ago. It sounded like it was coming from the right front somewhere. Turned out it was the right rear drop link that had loosened up a bit. Probably not a bad idea to check them from time to time.
You could just split the difference and go 63, a couple pounds either way shouldn't matter. Perhaps someone who has a factory manual could look it up.
Kurt
Old 11-23-2011, 06:18 AM
Northern Motorhead
wildcat077's Avatar
61 ft/lbs ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 11-23-2011, 07:43 AM
KTL KTL is online now
Schleprock
KTL's Avatar
61 ft lbs for M12 is not that high. The engine and transmission mount bolts are M12 also. They're torqued to 58 ft-lb. I believe the sway link bolts are fine thread, so it would make sense the spec would be a bit higher. Also for reference, BMW wheel bolts are M12 size and torqued to ~80 ft-lb. Its a common size (1/2 in. or 12mm) for alot of cars' wheel studs.
Bottom line is you're fine in the 60 ft lbs range.
Kevin L
'86 Carrera "Larry"
Old 11-23-2011, 08:13 AM
steely's Avatar
Kurt / Phil / Kevin
Thanks for the info - I have the parts and am planning my winter projects, sketching (writing) out the approach when I found this stumbling block.
it's appreciated!
Dan
Venetian Blue
Old 11-23-2011, 03:06 PM
Northern Motorhead
wildcat077's Avatar
Dan,
You have no idea how many times i removed and reinstalled the R/H side torque link bolt when i changed my spring plate bushings and installed and reindexed 29 mm torsion bars ... lol
All that to get the perfect ride height (fought a whole afternoon for 1/4 inch )while leaving the eccentric adjuster in the neutral position to make corner balancing easier !
Torqued it to 61 ft/lbs over a dozen times
Good luck with your projects !!!
Cheers !
Phil
Cheers
Phil
Old 11-23-2011, 04:51 PM
