Why no love for me on this BBS?!
Can somebody answer my question about removing the rear heater blower? Can I take it out and leave it out for a while?
Old 03-30-2002, 09:01 AM
feelyx's Avatar
Mdrive,
Are you talking the one in the engine compartment? if so, yes, but you will need to plug the hole in the shroud. I believe I used a 4" rubber sewer cap with a hose clamp one time.
Hope this helps
Tim in Sac
Old 03-30-2002, 09:29 AM
MDrive, Do a search in the archives (see the buttons up in the top right corner). This topic has been discussed before. Cheers, Jim
Old 03-30-2002, 09:56 AM
Jim Smolka's Avatar
Depending on the motor, you can plug the blower motor hole by using a plastic peanut butter lid and a big clamp. Worked for me
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-30-2002, 10:22 AM
Senior Member
Superman's Avatar
Yes, we love you. Yes, you can remove the blower motor and still drive the car. If you do this, you should plug the big plastic air scoop thing that is bolted to the big engine cooling fan housing. the other end is round and you can just take its normal hose clamp and use that to affix a sheet of plastic over the opening. This will direct more air over your cylinders, where it belongs and will prevent air moving in a loop between the cooling fan and the engine compartment. Since I removed my A/C, I took all that out and installed the early air handling system that does not involve a blower. Pics of the engine (complete with plastic sheet clamped to the left air scoop) can be seen in the recent thread called "Thanks and Smiles."
Mocha 1978 911SC. "Coco"
Old 03-30-2002, 11:59 AM
Of course, the obvious question is "why would you want to?"
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-30-2002, 12:01 PM
Administrator
Jack Olsen's Avatar
Yes.
Old 03-30-2002, 12:07 PM
The hole on my '80 SC is plugged using a cap from a spray paint can that is placed in the hole upside down and held in with a couple screws.
'80 Targa - Gone. No P-car until I have more time and money
My Pelican Owners Page
Old 03-30-2002, 02:20 PM
Thanky
Thanks for all the love.
I just want to pull it out temporarily to work on it and clean it up a bit. Will put it back later. I figured I would have to plug it to keep the air moving over the cylinders.
OK, well thanks again for all the posts.
Old 03-30-2002, 02:24 PM
