-   -   Lug Nut Socket Size? (http://forums.pelicanparts.com/porsche-911-technical-forum/642242-lug-nut-socket-size.html)
TeamAguilar 11-28-2011 04:43 PM
What size is the socket / wrench size for the standard Fuchs wheel? I can't find a replacement wrench for sale anyone on this site and was curious.
Can someone please tell me the socket size?
Shaun @ Tru6 11-28-2011 04:45 PM
19mm.
3/4 will also work.
TeamAguilar 11-28-2011 04:47 PM
Thank you, I know it's a dumb question but I have limited access to a Garage as I live in a high rise and most of my tools are in storage. :( Doing the simplest of things can be a real pain! SmileWavy
Originally Posted by Shaun 84 Targa (Post 6398082)
19mm.
Shaun @ Tru6 11-28-2011 05:05 PM
better a "dumb" question than rounded out and ruined lug nuts. :)
chadloose 11-28-2011 06:05 PM
On topic-ish: My original 19mm black lugnuts are pretty scuffed. Once I replace (assuming replace is best practice vs. re-paint/re-anodize), should I:
- get one of those special "non-marking" lugnut sockets
- or just be careful
Thanks!
ShakinJoe 11-28-2011 06:11 PM
Just be careful. You can polish them but they might look odd with black center wheels. My soft socket broke apart. Use a good quality 19 mm deep socket with a breaker bar and you should be fine. Most importantly, make sure you Torque the wheels to 96 ft lbs. Do not over tighten those aluminum jobbies.
Fishcop 11-28-2011 06:16 PM
There are also sockets that grip the "sides" rather than the "corners" of the lug nuts... sort of a 'star' shape when you look down the barrel; these cause less damage/buring/scuffing to anodized lug nuts.
pwd72s 11-28-2011 06:17 PM
You have a lady friend who uses panty hose? No, not being kinky here...try placing panty hose material between the socket and the wheel nut...my tip of the year.
Dantilla 11-28-2011 06:19 PM
I've touched up scuffed lug nuts with a black Sharpie pen. Unless you're going to have a Concours judge looking at them with a magnifying glass, they look fine.
Dantilla 11-28-2011 06:23 PM
With tools in storage, just these wrenches:
10mm,
13mm,
19mm,
you will be able to twist about 80% of the bolts & nuts used on a 911.
Shaun @ Tru6 11-28-2011 06:39 PM
adding 15 and 17 gets you to 95%.
Flat Six 11-28-2011 09:18 PM
+1
and a 19mm lug wrench should be in your frunk anyway . . .
TeamAguilar 11-28-2011 09:59 PM
Thank you for the tip!
10mm,
13mm,
19mm,
