TeamAguilar's Avatar
Lug Nut Socket Size?
What size is the socket / wrench size for the standard Fuchs wheel? I can't find a replacement wrench for sale anyone on this site and was curious.
Can someone please tell me the socket size?
1979 911sc owner in San Diego. My first post and story on the Pelican Forum can be read here - http://goo.gl/7WZjp
My favorite website can be viewed here - http://goo.gl/MPWUA Thank you, this is a great forum!
Old 11-28-2011, 04:43 PM
Shaun @ Tru6's Avatar
19mm.
3/4 will also work.
Tru6 Restoration & Design
Old 11-28-2011, 04:45 PM
Thank you, I know it's a dumb question but I have limited access to a Garage as I live in a high rise and most of my tools are in storage. Doing the simplest of things can be a real pain!
Originally Posted by Shaun 84 Targa View Post
19mm.
Old 11-28-2011, 04:47 PM
better a "dumb" question than rounded out and ruined lug nuts.
Old 11-28-2011, 05:05 PM
On topic-ish: My original 19mm black lugnuts are pretty scuffed. Once I replace (assuming replace is best practice vs. re-paint/re-anodize), should I:
- get one of those special "non-marking" lugnut sockets
- or just be careful
Thanks!
1985 Coupe, 2007 Cayman
Old 11-28-2011, 06:05 PM
ShakinJoe's Avatar
Just be careful. You can polish them but they might look odd with black center wheels. My soft socket broke apart. Use a good quality 19 mm deep socket with a breaker bar and you should be fine. Most importantly, make sure you Torque the wheels to 96 ft lbs. Do not over tighten those aluminum jobbies.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 11-28-2011, 06:11 PM
Bird. It's the word...
Fishcop's Avatar
There are also sockets that grip the "sides" rather than the "corners" of the lug nuts... sort of a 'star' shape when you look down the barrel; these cause less damage/buring/scuffing to anodized lug nuts.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-28-2011, 06:16 PM
pwd72s's Avatar
You have a lady friend who uses panty hose? No, not being kinky here...try placing panty hose material between the socket and the wheel nut...my tip of the year.
Old 11-28-2011, 06:17 PM
Non Compos Mentis
I've touched up scuffed lug nuts with a black Sharpie pen. Unless you're going to have a Concours judge looking at them with a magnifying glass, they look fine.
Old 11-28-2011, 06:19 PM
Non Compos Mentis
With tools in storage, just these wrenches:
10mm,
13mm,
19mm,
you will be able to twist about 80% of the bolts & nuts used on a 911.
Old 11-28-2011, 06:23 PM
adding 15 and 17 gets you to 95%.
Old 11-28-2011, 06:39 PM
Flat Six
Flat Six's Avatar
+1
and a 19mm lug wrench should be in your frunk anyway . . .
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 11-28-2011, 09:18 PM
Thank you for the tip!
10mm,
13mm,
19mm,
Old 11-28-2011, 09:59 PM
