-   -   Please tell me is this looks right/wrong? (http://forums.pelicanparts.com/porsche-911-technical-forum/6427-please-tell-me-looks-right-wrong.html)
Matt Smith 06-27-2001 03:26 PM
I used an engineering Roll Pin, tight a fit as possible, pressed and loctited into place. For those unaware, they are a hollow rod with a split down the side. Mr Hall confirmed this was fine, and I have had no movement whatsoever to date. I got a selection of them from a local garage and fount the one most suitable.
twin plugged targa 06-27-2001 05:34 PM
I was about to remove my distr. and dismantle shim etc then located a new distr. for $100!!!!!!!.
What the!!!!
So have ordered it and will fit it in a few days when I get a chance!.
Work comes first and tomorrow we take to the 'high seas!!!!'.
'Yo Ho Ho and a bottle of Rum' and all that! http://www.pelicanparts.com/ultimate/smile.gif
rgds Ben
Clark Griswald 07-14-2001 08:39 AM
I pulled my distributor yesterday to replace the cam oil line. Remembering this post I took the opportunity to inspect the end play.
Seems I have about 1 mm play in the same place as Ben's, above the fixed washer.
Question is, what is the range of acceptable end play?
Mine is also an '86.
Early_S_Man 07-14-2001 11:11 AM
Clark,
Ideally, less than normal valve clearance! New distributors and well oiled examples measure in the 0.001" to 0.003" range!
I guess I shouldn't be surprised that Bentley doesn't cover this matter! Realistically, I suppose the wear limit is around 0.010" to 0.012", so yours is over the limit by a wide margin!
Warren Hall
1973 911S Targa
movin 07-14-2001 03:27 PM
Ragtop,
Where did you locate a $100 bosch distributor? I'm looking for one too.
I guess this is problematic of the Carrera series distributors, not to mention the DME(ECU) failure rate as they age. WHAT NEXT!
pwd72s 07-15-2001 10:56 AM
Sorry it to me so long to come across this string. There is a distributor rebuilder near me. Located in Albany, Oregon. United Automotive Industries, 1-800-388-5336 or 541-928-5368. I needed a piece for my distributor a few years ago, and they were very helpful. They rebuild Bosch as a specialty, but also rebuild for Oregon's Ferrari dealer (Marelli), do mostly commercial work but would do work for an individual as well. Address on them is 221 SW 29th, Albany, OR 97321. Shop owners might take note. I was very impressed with my tour of the facility.
kepperly 07-24-2001 06:36 PM
I HAVE AN 87 911 W/ 78000 MILES AM I IN
EMINENT DANGER OF WALKING BACK FROM MY NEXT OUTING??
Kurt B 07-24-2001 09:21 PM
considering I have an 84 with 156k miles, I doubt it. No matter what, the car has never left me stranded!
Kurt B
1984 Carrera Cabriolet
911 Page
carrera_cabriolet@yahoo.com
