LinkBack | Thread Tools | Rate Thread |
1974 911 w/ 83 SC engine
Can a normal knucklehead DIY'er swap out spring plate bushings in an afternoon?
I have a day off tomorrow and have been needing to do something with my spring plate bushings for a while. Some one here said that you can actually just *swap* the plates from one side to the other, and it's just like getting new bushings. Some part of me thinks there must be a reason why NOT to do that or I would have heard about it being done a lot more often.
So my question is two fold: Is the spring plate side swap a viable option? And say I already have some Elephant racing OEM rubber bushings, how hard is it for an average DIY guy to actually swap out the bushings? My main concerns are: Is there a particular order to taking the spring plate bolts off? Are there any bolts I specifically SHOULDN'T touch? I know I'll need a very thin flanged socket to fit over the 4 cover bolts, right? I have the 101 projects book, but there isn't a real how-to for this project, the closest one is for lowering the car. And even the most detailed description I've read on how to do it leaves much to be desired. So ANY tips or info or links to either one of those would greatly appreciated--I don't want to waste a perfectly good day off tomorrow by not working on my car! |
RETIRED
On a scale of 1-10, it's a 7.5......indexing them can be a trial. I would replace the bushings.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Ruby911
I did everything you are needing to do short of removing the bushings from teh spring plates (had the spring plates out of the car and in my hand, bushing still attached.) Did both sides, including runs around the block and re-adjusting of ride height 4 times. I had a fellow Pelican lending a hand - started about 9:30 and ended about 2:30. It was not hard, just time consuming the first time you do it.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Ruby911
oh yeah, I am pretty much a knucklehead as well.
Under the radar
Speaking from experience this can be a frustrating and time consuming job. Do you have a way to measure the angle of the torsion arms accurately? Do you have a floor jack and an impact wrench? How will you restore the alignment settings?
What I would recommend, which is what I did a number of years ago on my 911 with great success, is just replace the outer rubber with a plastic bushing. You only have to take off the retainer. You won't have to disassemble the torsion arm from the control arm or take off the shock. Most importantly you won't have to re-set the alignment. Setting the rear alignment can take quite a bit of work by itself. My car rode smoother with the plastic bushing. I think it was because the old rubber bushing allowed metal to metal contact between the torsion arm and the retainer. Just be sure to use the graphite impregnated bushings, not the red SAW ones. I think switching sides would only be a short term solution.
I'm here to cause trouble
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
Is this a Daily Driver? if so, I wouldnt.
Can you do it in an afternoon? Maybe. I believe that if your not going to do it right... your better off not doing it... Take your time. Change the bushings, the bars (if they have been rubbing), and get a proper alignment and CB. this is one area where you shouldnt cut corners... I did mine, front and rear. didnt take me longer than a weekend...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 05-04-2010 at 07:32 PM.. |
it took me a solid whole day to replace all the bushings with the Black elephant racing types.
Removing the original rubber bushes was tough but doable. The advantage of being a knucklehead like myself is we are persistent. ![]() Mark any surface you can for the closest reinstallation. Then after, a visit to the alignment shop, it is still a must to recheck camber, caster etc. I wanted to lower the car abit more, and what i did was to go one serration up from the original position. Work out fine and car was still level. Corner weights maybe affected too. Unfortunately, my part of the world don't have shops equipped to check this out for us. Also, i installed a grease nipple into the end cap of the Torsion Spring. Even the Black ones started to squeak after a while. So this allowed me to pump Moly without any uninstallation. |
Getting the plate angle/ride height right after re-installation is the biggest thing I am worried about. I've read that marking everything exactly where it is before taking it apart helps with re-installing it. But I know that's not going to be enough.
Also, is replacing the trailing arm bushings a smart idea while the plates are off, or is one job not related enough to the other to warrant the consideration? |
Start early in the morning and don't stop until you finish. You will be tired.
The absolute best solution is to replace the spring plates with new factory ones with bonded bushings, but thats an expensive alternative. By the way, obviously you can only do the "swap" once! You could ask, but I think Ruby911 is quite pleased with his swapped spring plates.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 05-04-2010 at 08:33 PM.. |
Given that you already have the bushings, I can't imagine any reason not to change them. Even if the opposite side of the old rubber has some bulk, it certainly won't have the spring that a new set would. Changing them is really the least difficult part of this whole procedure. A torch and a sharp carpet cutter and the old bushings will be off in 15 minutes. The new ones fit on easily. They get super-glued on, and should probably be left a day to set before reinstalling, but that's the only thing that would prevent this being a relatively quick job. (Quick, I mean, in relative terms; you can still expect some fun getting everything off the car, and then there's indexing and alignment...)
Mike
Michael Caterino Clemson, SC 1970 tangerine (=Tiger Orange) 'T' targa restoration: mk911.blogspot.com Last edited by mcaterino; 05-04-2010 at 09:55 PM.. Reason: add disclaimer |
I'm a loser, baby.
Did I hear JB Weld in one post?
1979 911 SC |
neither did i. I never glued them on. Yikes.
They were dang tight though. I remember i had to chamfer the edges to get a lead for installation. Literally had to bang the suckers in |
Ruby911
Yes, we swapped the springplates on Ruby, and all seems well. If I had planned a little better in advance, I probabaly would have installed new bushings, but I was standing there in the garage with the rear suspension scattered all over the floor when that tought crossed my mind. The car feels nice and tight as is.
>So, just normal super-glue? Or is there a proven brand or type that everyone uses?
I replaced mine this spring with the Elephant racing rubber parts and used a Loctite product called "Black Max" which is an industrial cyanoacrolyte adhesive (super glue). It's basically a super glue mixed with rubber to improve the shear strength which I think is what you need. We use it where I work and I looked up the properties and it looked like the right stuff. Only had the car about for about a month but so far so good. The car isn't really any tighter but the road noise is much improved. I emailed Chuck at Elephant about this adhesive thinking he might have some input or interest but never heard back. Probably gets a lot of stupid questions.. Mike |
If you're going to all the trouble of doing new bushings et al, you ought to install adjustable spring plates! Given you have a "74, unless a previous owner installed adjustables, you still have the old non adj plates.
Indexing the plates and getting the ride height correct without adj plates is a nightmare! You'll find used ones on the for sale forum all the time at reasonable prices or perhaps put a WTB request on the forum. Believe me, they will make your "bushing job" tolerable.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
While I think Elephant makes excellent products, the documentation does leave something to be desired. Something this unintuitive should certainly be specified with the product. Mike
Michael Caterino Clemson, SC 1970 tangerine (=Tiger Orange) 'T' targa restoration: mk911.blogspot.com |
