schumicat's Avatar
defeated by ball joint wedge pin
I have given up trying to get the ball joint wedge pin out. I suspect it has been in place for 30 years. I pounded the *&#$ out of it with a 3 lb. mini sledgehammer after spraying with PB Blaster (for 2 weeks) and Wuerth Rost Off Ice (which is now very hard to find and cost $23 shipped). Trying to decide whether to buy a puller (which I see some have used) or have shop do it. I didn't try heat because I don't want to ruin the ball joint boot and have it still stuck in place.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-03-2011, 07:40 AM
drill out the big end to collapse it a bit. like drilling partially through a valve guide before running it out of the head. large as possible without getting into the strut metal.
206 637 4071
Old 12-03-2011, 09:39 AM
Chief Head Scratcher
kerthunk's Avatar
I used a shop press to push mine out. I picked one up at harbor freight. It has been handy for a bunch of little projects on the car.
12 Ton Shop Press
John Morris
'79 911SC
Old 12-03-2011, 09:51 AM
Nine9six's Avatar
I soaked mine in PB Blaster, and ran an old nut onto the threaded end flush to increase the surface area and gave it a good smack with a BFH. This worked like a champ on both ball joints.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-03-2011, 05:48 PM
