-   -   Engine lid gas support strut. Where it goes? (http://forums.pelicanparts.com/porsche-911-technical-forum/643164-engine-lid-gas-support-strut-where-goes.html)
caribdis7 12-04-2011 02:08 AM
Dear all,
I am trying to understand where it goes the engine lid gas support(s). My car came without them but I can not figure out where they have to be installed.
I ve check Bentley manual but the darwing doesn't show where itis connected.
Can somebody show me in a photo where have to be installed?
Are they 2 or only one?
Help is very much appreciated.
Regards
Targa Time 12-04-2011 02:19 AM
I just happened to have this photo. It should help.http://forums.pelicanparts.com/uploa...1322997581.jpg
caribdis7 12-04-2011 12:51 PM
Quite clear now. That is why I couldnt see it in other engine photos.
Many thanks.
Do you know if it has the gas strut in only one of the hinges, or it goes in both?
Regards
hcoles 12-04-2011 01:18 PM
I think turbo has two, standard is one
fbeatty 12-04-2011 01:35 PM
My 88 Targa is not a turbo, but has a tail and it has 2 struts on the rear. I need to replace the front and rear.
chococrazy 12-04-2011 02:30 PM
My 89 SAE has two. Pretty easy with long hemostats or curved pliers.
hcoles 12-04-2011 02:35 PM
I went back out and checked, there is a bracket on both sides on the body but only one lid arm has a bracket, I was looking to put two gas struts in but couldn't. Seems like they last a good number of years then need replacing.
hcoles 12-04-2011 02:51 PM
caribdis7 12-05-2011 12:55 PM
I ve checked and mine has only one support.
Many thanks everybody
Vincent Hill 12-05-2011 01:20 PM
Most only have the one on the Body and engine lid on the Left (Drivers Side) of the car. If your Engine lid is heavy and 1 strut is not doing it, you can mount a second on on the same side. I am using 3 bad struts on the left side the Whale Tails are a lot heavier.
All you need to do is use Longer Bolts and a spacer then use a Nylock Nut or double nut the bolt so it does not come loose.
Tidybuoy 12-05-2011 02:36 PM
My car has only one strut on the driver side and the engine lid opens fine.
I and see your desire to have two but the factory only put two in for cars with whale tales and a/c condensor.
Stan Gillis 12-05-2011 03:40 PM
I needed to install two new gas struts to enable to hold my new fiberglass duck tail. However, there were two used on the old standard deck lid.
DRACO A5OG 12-05-2011 08:29 PM
The standard lid without tail originally came with one bracket, driver side.
Aftermarker tail (turbo/carrera) install, required two, so people improperly installed a dual strut which caused the lid to deform when closed.
The real Turbos have the bracket on the passenger side lid hinge. Luckily PAG designed (or at least on the 3.2) a bracket for a future install of a strut but it requires a Turbo lid hinge.
Some have welded a bracket to accomodate for passenger side strut.
I ended up swapping my OEM hinge for a turbo hinge to keep the lid straight and keep my tail up :D
