caribdis7
Engine lid gas support strut. Where it goes?
Dear all,
I am trying to understand where it goes the engine lid gas support(s). My car came without them but I can not figure out where they have to be installed.
I ve check Bentley manual but the darwing doesn't show where itis connected.
Can somebody show me in a photo where have to be installed?
Are they 2 or only one?
Help is very much appreciated.
Regards
Old 12-04-2011, 03:08 AM
Targa Time's Avatar
I just happened to have this photo. It should help.
Old 12-04-2011, 03:19 AM
caribdis7
Quite clear now. That is why I couldnt see it in other engine photos.
Many thanks.
Do you know if it has the gas strut in only one of the hinges, or it goes in both?
Regards
Old 12-04-2011, 01:51 PM
I think turbo has two, standard is one
Old 12-04-2011, 02:18 PM
fbeatty's Avatar
My 88 Targa is not a turbo, but has a tail and it has 2 struts on the rear. I need to replace the front and rear.
Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium and Strontium 90)
08 Cayman, 88 911 Targa, 93 MR2 Turbo, 2012 Jeep JK
Old 12-04-2011, 02:35 PM
My 89 SAE has two. Pretty easy with long hemostats or curved pliers.
Old 12-04-2011, 03:30 PM
I went back out and checked, there is a bracket on both sides on the body but only one lid arm has a bracket, I was looking to put two gas struts in but couldn't. Seems like they last a good number of years then need replacing.
Old 12-04-2011, 03:35 PM
Old 12-04-2011, 03:51 PM
caribdis7
I ve checked and mine has only one support.
Many thanks everybody
Old 12-05-2011, 01:55 PM
Most only have the one on the Body and engine lid on the Left (Drivers Side) of the car. If your Engine lid is heavy and 1 strut is not doing it, you can mount a second on on the same side. I am using 3 bad struts on the left side the Whale Tails are a lot heavier.
All you need to do is use Longer Bolts and a spacer then use a Nylock Nut or double nut the bolt so it does not come loose.
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 12-05-2011, 02:20 PM
My car has only one strut on the driver side and the engine lid opens fine.
I and see your desire to have two but the factory only put two in for cars with whale tales and a/c condensor.
Old 12-05-2011, 03:36 PM
I needed to install two new gas struts to enable to hold my new fiberglass duck tail. However, there were two used on the old standard deck lid.
Old 12-05-2011, 04:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
The standard lid without tail originally came with one bracket, driver side.
Aftermarker tail (turbo/carrera) install, required two, so people improperly installed a dual strut which caused the lid to deform when closed.
The real Turbos have the bracket on the passenger side lid hinge. Luckily PAG designed (or at least on the 3.2) a bracket for a future install of a strut but it requires a Turbo lid hinge.
Some have welded a bracket to accomodate for passenger side strut.
I ended up swapping my OEM hinge for a turbo hinge to keep the lid straight and keep my tail up
'85 Carrera Targa
PCA/POC
Old 12-05-2011, 09:29 PM
