vracer's Avatar
SF Bay Area - Targa top
It's time to replace the rubber over the side windows and adjust the windows to seal. If it were just a top repair, it would go back east, but to adjust the windows to the top requires a local shop. Local suggestions please?
Richard
1989 Venetian Blue Targa
Old 12-05-2011, 11:56 AM
Member 911 Anonymous
DRACO A5OG's Avatar
How about I send you a shop manual so you can DIY?
PM me your email address and I will send it to you. The most important thing is to make certain the "parallelism" are parallel to the side seal and use the screw on the side seals to move them out accordingly. Best way to do this is to lower the window about 1/4 inch then adjust. Once windows are up make sure the height adjustment actually goes into the rubber guides on the side seals. Note the height must not be too high or you will get wind noise and it will bind the guide lip. I would stick a ruler up the guide to see how much room you actually have. You want a little room for Targe Flex as the top needs to settle on the window while driving.
'85 Carrera Targa
PCA/POC
Old 12-05-2011, 09:52 PM
