echecsqueen's Avatar
footwell blowers
My footwell blower seized again and in trying to free it up i broke the fan. The other one is on its last legs as well....Does anyone know of a better/cheaper aftermarket replacement...I am tired of replacing the fans and motors.....
Blower Motor Assembly 91162404402 - Genuine Porsche - 911-624-044-02 | Pelican Parts
415.00 EACH
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 10-03-2017, 07:29 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fans.
415.00 EACH
This is not an uncommon issue.
I have been "Hounding" our host to stock just the fan motors
which should not cost more than $125.
There are several threads on this forum which show
steps for fan replacement using the evaporator(?),
or front condenser(?) motor with slight modifications.
Also, please check our used parts forum.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-04-2017, 04:43 AM
I removed mine years ago. Don’t need them here in north Louisiana!
Old 10-04-2017, 05:39 AM
Vintage Owner
Jack Stands's Avatar
911s got by with many years without any fans boosting the output through the heat exchangers, and only added electric fans when the heat exchanger design was changed in 1975. I assume these were added to aid in defrosting the windshield, but I never noted any lack of heat in my old Porsches. Removing the squirrel cage blowers in the foot wells may not have that much difference in airflow and you can always shift down to a lower gear to increase the output of the engine driven fan.
Has anyone not had adequate heat or defrosting if they removed these fans?
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 10-04-2017, 06:09 AM
Eng-o-neer
Tremelune's Avatar
Yeah, you're fine without them if you have an engine blower or even just the engine fan attached. They can be replaced with simple tubing.
If not...I vaguely recall someone found out what the motor was (or a drop-in replacement) that was much, much cheaper. Alas, I didn't save the thread.
Old 10-05-2017, 08:13 AM
Formerly known as Syzygy
Canada Kev's Avatar
Some info here on footwell blower motor replacements...
Replacement footwell blower motor solution
Kevin
Old 10-05-2017, 09:19 AM
