Rennch on YouTube
Porsche repair shop in Atlanta?
We need to get some clutch work done on a Boxter...anyone know a shop (other than the dealer) that fixes Porsches in the Atlanta area?
Thanks, mike
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
RSDbabe
Thank you for the help!!
I have never used either but I have also not heard any bad word of mouth.
Rylands Specialized Import Service 2002 Airport Ind Park Dr SE Marietta, GA 30060 (770) 951-9305 Franz Blam Racing Thomas.Blam@franzblamracing.com 2040 Steel Drive Tucker, Georgia 30084 Phone (770) 939-6100 Fax (770) 939-9036 |
Some here don't like him...But my brother and I have always had great luck with Reggie at Pro Formance Place on South Cobb Drive in the Smyrna/Marietta area.
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
I use Dieder at Franz Blam. They do excellent work and get it done by when it is promised.
John '86 911 Coupe |
Semper drive!
Mike (emptyo),
It really depends on what part of Atlanta you're talking about. Ryland's place is northwest Atlanta, and receives my highest recommendation. He's a real knowledgeable, stand up guy that does quality work. On the northeast side is where Franz Blam Racing is located. There is more info if you do a search...like this thread. Cheers! Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Mike, are you visiting Atlanta? We are a couple of hours north and would love to catch up.
Ben
1986 3.2 Carrera |
Insert Tag Line HERE.....
Premier in Alpharetta is run by Kerry, great guy/shop. Also Rylands as mentioned.
Rennch on YouTube
Whoa...hey Ben! I lost track of you guys. I am not visiting Atlanta, but I did last year. Drop me a line at racercl at gmail dot com and we'll chat.
I've got to put a plug in for Jim Kimmey who owns European Import Services in Suwanee. 770-932-5267
I had a starting problem that was looked into at another shop - discussed on this board and another without results. I talked to Jim at length on the phone and he came up with the correct plan that fixed the issue. I even drove my car up to Suwanee from Norcross one evening and he drove me home - he lives in Tucker. Great guy.
'85 RoW 911 Coupe '65 356 SC '72 BMW 2002Tii '10 Cayenne '20 Ram Longhorn |
Rennch on YouTube
Thanks for the tips.
Has anyone done a clutch in a Boxter? Is it DiY friendly?
Should you consider heading southward around 80 miles, there's a great wrench in Bolingbroke that I use: James Roberts of Roberts' Automotive. VERY professional,..and VERY Porsche,..maybe a bit cheaper than the Atlanta market (possibly). He's my go to guy.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Rennch on YouTube
I think the only issue would be getting the car down there. That's going to be a challenge...
In the shop at Pelican
It's not that difficult, but you will require a speicalized Torx socket to remove one of the bolts holding the tranny to the engine. I had to cut it down with the Dremel and slip a 13mm wrench over it. You will need to remove the suspension crossmembers/underplate, exhaust, CV shafts, shifter cables, and the tranny mounts. Obviously, support the engine and use jackstands when underneath. |
Porsche Repair Atlanta
The best place to go BY FAR is Cali Auto - they are in Stockbridge, but they will pick your car up for you. Here's their website: Porsche Repair Atlanta
They also do a lot of canvas top replacements too: Porsche Canvas Top Repair Atlanta You will just love Scott & Megan
