-   -   A/C upgrade (http://forums.pelicanparts.com/porsche-911-technical-forum/64361-c-upgrade.html)
civil-tech 03-30-2002 11:32 PM
A/C upgrade
I am thinking about upgrading my 83 SC 3.0 to the newer style rotary compressor. Can anybody give me a heads up on this conversion? Does the bracket have to be modified much?
chuckr 03-31-2002 05:16 AM
It depends on the brand of compressor you go with.I went to the Sanden rotary comopressor on my 83SC and had to have a new bracket made.
Jadams1 03-31-2002 06:54 AM
1 Attachment(s)
The previous owner did the conversion. It looks like a new compressor bracket was welded to the original mounting platform.
Here's a picture of the compressor mount. I had to remove it to do the chain tensioners which made for a good photo opportunity.
John
GeorgeM 03-31-2002 07:44 AM
Since you'll have the system open, if you really want cold a/c, check this out:
Pro Cooler
Roger Chafen 03-31-2002 10:22 AM
Replaced the original York last year on my '79SC-bought the kit from Griffiths-compressor w/bracket, all new barrier lines & drier. Everything was an exact fit-even reused the belt
Roland Kunz 04-01-2002 01:44 AM
Hello
There is a Zyxxel aviable who is a direct ( You have to change the hose block ) replacment for the later ( 3,2 L ) Denso units. I think the application is VW, Mercedes and Volvo.
However they are in rotary vane or woble drive aviable.
Grüsse
