-   -   Can you use a SC Bleeder Valve on a 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/643634-can-you-use-sc-bleeder-valve-3-2-a.html)
DRACO A5OG 12-06-2011 01:55 PM
Okay Fellas,
3.2 Front Caliper Bleed Valves are only available from Germany PAG, kinda want not to have to wait :-(
Has anyone tried to use SC valves on a 3.2?
TIA,
Jim
Ian Comerford 12-06-2011 01:59 PM
Hi Jim,
The 3.2 caliper is the same as an SC except that there is a spacer inserted between the two halves to allow for thicker discs so the bleed nipples should be the same
DRACO A5OG 12-06-2011 02:01 PM
Interesting, I may just give it a try. Thanks Brother English :D
Flat Six 12-06-2011 02:40 PM
Originally Posted by Ian Comerford (Post 6414794)
Hi Jim,
PP lists the same Speed Bleeder valve for both 78-83 and 84-89 front calipers (A and wide-A): Porsche 911 & Carrera Brake Hydraulics - Page 1
Useful parts interchange summary, too:
-- 'M' Front & Rear brake calipers are made of Steel and have approximately a 3 inch, center to center, bolt spacing. These were used as front calipers up until early 1975.
-- 'S' Front brake calipers are made of Aluminum and have approx. a 3 1/2 inch, center to center, bolt spacing. These were used on some 911s and all 911 Turbos between 1974 and 1977.
-- 'A' Front brake calipers are made of Steel and have approx. a 3 1/2 inch, center to center, bolt spacing. These were used on many mid-70s 911s and practically all 911SCs. Beginning in 1984, the Carrera used wider versions of 911SC calipers - the 'wide A' and 'wide M'.
DRACO A5OG 12-06-2011 02:53 PM
Oh very Cool Flat Six!
Okay, if I am reading correctly:
OEM Standard Bleeder Valves are:
911-351-919-01-OEM Bleeder Valve, front 'A' caliper (sold per each), 911 (late 1975-83)
911-351-919-02-OEM Bleeder Valve, front caliper (sold per each), 911 Carrera (1984-89)
Then if you read the Speed Bleeder Valve Specs, it should match:
Speed Bleeder Valves, "A" Front Caliper (sold per pair, one valve per caliper)
Front 911 (late 1975-89)
I will post my findings,
Jim
rnln 12-06-2011 04:51 PM
When you say 3.2 bleeder, do you include my 88 bleeder too? If so, I think I have one extra, brand new. If you are ok with used, then I think I have an old one too. Let me know, I'll look for them.
DRACO A5OG 12-06-2011 04:56 PM
Thanks Rnln,
I actually order the front SC valve and new Carrera 3.2 84-89 rear valves, new.
According to the Speed Valve Specs for their front speed valves it is for 75-89 so I am hoping the SC OEM valves will be the same OD and pitch as the 3.2 Carrera valves.
Jim
rnln 12-06-2011 05:06 PM
ok Draco, I didn't know front and rear are different but my are front. You know where they are now if you need them quick.
DRACO A5OG 12-06-2011 05:09 PM
Thanks Brother Rnln! :D
DRACO A5OG 12-09-2011 10:42 PM
Update:
The answer is weird YES on my 3.2:
911-351-919-01 will fit on both Front and Rear Calipers on my '85 3.2, Does this mean POs or Retard Wrench threaded in a front bleeder valves on my rear calipers? But Why???
The spec on the 911-351-919-01 are 8MM OD thread with 9MM Hex plus Rubber Cap included :D
http://img.photobucket.com/albums/v5...209_120738.jpg
Strangely enough, PAG spec calls for 901-352-977-10 on rears but it is way too small in OD to fit in the rear calipers on my 3.2 :eek: Also looking at the PAG numbers for the front 911-351-919-02 with out cap
Has anyone else experienced this???
