tassie targa 76's Avatar
can't select reverse
after a bit of passionate drive today lots of twisty roads. i got home and can't select reverse i have a 76 911 targa standard set up 2.7 with a 5 speed manual 915\44.
any ideas
Regards Michael
project 1976 911 targa
everyday drive 1995 318i BMW
wifes car 2001 c200 kompressor coupe
spare 2006 mazda bravo ute
Old 12-07-2011, 11:14 PM
RETIRED
Joe Bob's Avatar
First thing, check the coupler under the access panel behind your front seats. Does the shifter have excess 'play'?
Second, when was the last trans fluid service? If you can't remember, prolly time for one. Inspect fluid and magnetic plug for metal.
2012 ML350 3.0 Turbo Diesel
Old 12-07-2011, 11:30 PM
80-911SC's Avatar
what he said ... just adjusted one on a friend of mine's 86 today ...
Old 12-07-2011, 11:42 PM
no excess play select 1-5 all good but seams to be jamming and the stick wont go into reverse
Old 12-08-2011, 12:54 AM
fred cook's Avatar
No reverse......
Check the reverse lockout plate at the shifter. It may have been damaged somehow.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 12-08-2011, 04:29 AM
arry911
I would check the clutch cable you might need a small ajustment.A couple of mm can make a big difference.
Old 12-08-2011, 06:29 AM
