Paul, thanks for the help. I think a couple other people on the forum have used this ignition with a locked distributor already with carbs or some other setup that they had to change the timing with. I am basically just trying to find a solution/ fix for a crapped out vacuum advance (a part that is no longer made). So it adjusting/ twisting the dizzy just changes Idle advance, then yeah, I agree that it wouldt do anything for me. But if it effects the advance across the whole rpm range, then it could be very helpful, because I would just retard the timing with the MSD when I need to and not lock out the dizzy. I was thinking of running a couple extra degrees of advance across the rpm range and use 92+ octane, not a large gain, but a little. I dont care about gas milage, to be honest, as I dont drive it every day, and dont put a ton of miles on it. So just to clarify once more, sorry for my lack of knowledge, does turning the dizzy to adjust the timing create more advance across the whole rpm range? If so, I could get the stock, or with a couple degrees extra advance, without using the vacuum ad. (this idea was used by a member in the link to the other thread I posted, and it sounds very smart to me).
'80 911 sc '96 Range Rover |
So just to clarify once more, sorry for my lack of knowledge, does turning the dizzy to adjust the timing create more advance across the whole rpm range? If so, I could get the stock, or with a couple degrees extra advance, without using the vacuum ad. Scott, If you don't care about gas mileage, you are wasting your time and money worrying about a vacuum advance. Yes, turning the distributor and raising the initial timing effects the advance throughout the rpm range. The mechanical advance inside the distributor is speed related. If you start at 5 BTDC with a stock distributor that has a 10 degree (20 crank) mechanical advance, you wind up at 25 BTDC max. If you bump up the initial to 10 BTDC, you wind up at 30 BTDC max. The mechanical advance is speed related and the distributor does not know or care if the engine is at rest in neutral or under full load at 140 mph. But the engine does. What you are missing is that vacuum advance is a load based system, it only adds advance under light load cruise when VE is low and the engine can handle the extra advance without detonation. Under load at WOT it adds nothing. You can't replace the extra 10 degrees of vacuum advance by bumping up the initial, you will have too much timing under load and your pistons may wind up like these: What caused this engine damage The 911 is a knock limited design and the later small port SC is detuned for 87 CLC fuel by severely retarding the max advance from the ideal. You may get away with one or two extra degrees with premium fuel and a cool climate, but everything else (mixture, compression, ring seal, blow by, cooling) has to be perfect. My advice would be to look for a used stock distributor for a stock engine, disassemble and clean it, and run it without the vacuum retard. Keep your current distributor as a spare, and if and when you modify the engine with carbs and cams, have your old one recurved or lock it out and use the MSD
Paul |
