There is no substitute
Cat bypass
Does removing the cat really make a noticeable change in performance?
The Hacker
96 C4S
97 C2 (Gone, but not forgotten
Old 12-07-2011, 01:12 AM
NewfieMZ3's Avatar
Nope
1984 911 Coupe
2007 Z4 M Coupe
2008 Cayman S
2004 M3-Alpine White(sold)
2002 M Roadster (sold)
Old 12-07-2011, 05:48 AM
jackb911's Avatar
You will gain a very small HP increase in the upper RPM ranges at the expense of some low end response. At least that has been my experience.
I'd recommend going with a Euro-style pre-muffler. M&K and Dansk make nice ones.
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 12-07-2011, 05:55 AM
ivangene's Avatar
do you consider back firing on deceleration an improvement?
damn thing!
Ed M
86' Coupe
Old 12-07-2011, 06:35 AM
Decolliber's Avatar
I installed a Dansk bypass and a Steve Wong chip at the same time; the improvement was quite noticeable. Placebo effect maybe ...?
John C
1988 911 Carrera coupe
2002 BMW 530
Old 12-07-2011, 09:44 AM
Rescuer of old cars
Arne2's Avatar
My car came to me with an M&K pre-muffler and Wong chip already installed. I've not driven it with the stock cat and chip. It does pull hard at high RPM, but I suspect most of that is the chip, not the lack of cat.
damn thing!
Mine has never back fired on me, ever. Not once.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 12-07-2011, 10:08 AM
arbita1's Avatar
It depends on the car. You should put which car you have in your signature so the responses you get can be more fine tuned to what you're looking for.
Matt.
83 911SC
85.5 944 NA - Sold
Old 12-07-2011, 10:20 AM
Agfours
agfours's Avatar
it will if your cat was plugged up!
Paul
Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..."
Old 12-07-2011, 11:50 AM
I put the M&K premuffler on mine and noticed a gain but it wasn't huge. I got more bang for the buck from the Steve Wong chip. I have never had mine backfire either.
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 12-07-2011, 12:01 PM
Audible hp
Ryan- Sad day when my 83 911 left me
Old 12-07-2011, 12:07 PM
KNS KNS is online now
The benefit is small but it does remove quite a bit of heat form that side of the engine. When I changed out Oil return tubes the O rings on that side of the engine seemed a little more heat-fried than the right side.
Kurt
Old 12-07-2011, 12:09 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
also, there is a weight reduction!
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 12-07-2011, 04:16 PM
sbmackie's Avatar
Removing cat effect:
I actually dyno'd my car with and without a cat (I have an '82 SC; it also has a modified stock muffler, as in all the baffling is out save one). There was a 9 HP difference without the cat. I have a test pipe with an O2 bung and a functioning 02 sensor. The high reading is also with a modified airbox cover (cut both ends off, made a .3 HP difference. Hey, .3 HP for free in a 911 is a very good thing).
The first two runs were with cat, the last was without. No other changes.
Cheers
Scott
Old 12-07-2011, 06:29 PM
jackb911's Avatar
Notice the drop in HP and torque below 3K rpm with the cat removed. This mirrors my "on the street" butt dyno and shows that the reduced back pressure with the cat removed negatively affects the low end response.
I'd love to see a similar dyno chart but with a pre-muffler. I'm guessing that the results would be similar.
Thanks for posting the chart, Scott!
Jack
2007 GT3
Old 12-08-2011, 07:23 AM
sbmackie's Avatar
true that, but:
Yep, you lose a bit off the line. But, in the working RPM (in my car's case, 2800-5200 RPM), you gain both torque and HP. For my purposes (AX/some DE/general street use on nice days) it works well.
I'd bet the "sport" stock muffler has more to do with HP/torque gains then the lack of a cat. Cat weighs a ton, as well.
The next performance upgrade will be SSI's and a two in two out. I'll dyno it again after that.
Cheers and hope to see you at a local event.
scott
Old 12-08-2011, 07:35 AM
rfloz's Avatar
I like to think of the backfiring as adding "character".
M&K one-in/two-out and premuffler, not cheap.
Third to second downshift and back out of the throttle in tunnels - priceless.
And, before anyone asks, I have no intention of growing up.
Nice to see some documentation of added power, not that any rationalization was necessary.
Bob F.
1984 Carrera Factory Turbo-Look
Old 12-08-2011, 10:58 AM
Spiderman
Jesse16's Avatar
Agree with "Placebo" performance for daily driving. Probably more at the track. My bypass (not pre-muffler) made the car louder. Mostly I'm glad I removed the cat as the insides were mostly melted/gone/junk. Bit cleaner look now. Plan to get the SW chip and most say thats about all you can do to get more power without big $$.
I'd say removing the cat is a good first step, prepare for more noise.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 12-08-2011, 11:15 AM
Reiver
Reiver's Avatar
[QUOTE=rfloz;6419396]I like to think of the backfiring as adding "character".
I haven't had any backfiring issues since I've removed the cat. Ran it at 120 mph today and 80+ consistently. Did some quick deceleration with that too.
Have the 3.0 mixture set at 3.5 CO.
I think I'm going to weld a Small retractor in the pipe for a bit of BP to see if I can sharpen up the off the line.
I do notice an improvement without the cat when really on it above 3k though.
Old 12-08-2011, 11:16 AM
sbmackie's Avatar
backfiring?
Hmm, not sure what I'm hearing is backfiring. I like to think of it as a nice crackling sound. It doesn't bang, it crackles melodiously.
When I leave for events early of the AM, I am careful with the throttle. My wife says she can hear me accelerate through the gears on the main road outside our subdivision. Many complements on the sound from other track/AX types. Who cares what the civilians think.
Oh yeah, I've got the decel valve out of the fight as well, don't know if that makes any difference to backfiring or not.
Cheers and happy cat removing.
Scott
Old 12-08-2011, 03:58 PM
Reiver
Reiver's Avatar
Scott
I think the proper auto word for that is "burbling" isn't it. What all hard run cars should do btw...
Old 12-08-2011, 04:02 PM
