help with rear turbo flare alignment
hi everyone , i just got my rear turbo flare yestoday , and i m try it on today , is this flare alignment see ok ?
Old 12-08-2011, 05:59 PM
DONT do any welding until you have a rear bumper on the car, that is really the only way to ling them up correctly
Old 12-08-2011, 06:02 PM
thanx . i try with rear bumper and this is came out .
Old 12-08-2011, 06:11 PM
Air Medal or two
afterburn 549's Avatar
Yes the more things that are in place will dictate your correct fitment
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 12-08-2011, 06:36 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
dont do any welding until you have a rear bumper on the car, that is really the only way to ling them up correctly
+1.
Old 12-08-2011, 08:43 PM
redstrosekNic's Avatar
Give us some more pictures of your build!
Dustin
Old 12-08-2011, 08:48 PM
i also mod the 964 c2 front caliper to fit on my boge stut , by the way is this boge stut ? . the new rotor is coming soon, the back will be 3.2 rear caliper also will fit 3.2 rotor .
Old 12-08-2011, 10:19 PM
Tom '74 911's Avatar
Read through this thread where eimkeith gives some rear flare location dimensions on page 3 - compare them to how yours fit w/the bumper and end up where you need to be. . .
welding flares, longhood RSR, alignment questions.
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 12-09-2011, 07:53 AM
boba's Avatar
It is a good idea to do final fitting before welding with the wheels and tires that you will be using and at the final ride height.
Old 12-09-2011, 09:25 AM
grateful user
don gilbert's Avatar
everthing above, but a most critical measurement is from the inner wheel house out to the lip of the flare at the 12 o'clock position.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 12-09-2011, 02:19 PM
