too many projects 1983 sc
stripped front targa pin need advice
hi,
top on my 71 was replaced many years ago and while removing the pins for new skin one was loose, upon inspection looks like it was cross threaded and threads at the bottom of the pin are stripped. i cant seem to get behind to run a tap or replace the nut( cant tell if its bad either!)...any suggestions on a fix to get the new alignment pin to hold tight. copper wire, helicoil? anyone have a used pin? regards, ben |
problem solved copper wire super tight top is great... nice and tight as well , end of thread. ben
Senior Member
If you need parts, Dan Petchel on this forum who restores these tops has all of that stuff...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
