-   -   Turn signals do not work but Emergency Flashers do (http://forums.pelicanparts.com/porsche-911-technical-forum/644230-turn-signals-do-not-work-but-emergency-flashers-do.html)
Number1_dog 12-21-2011 12:54 PM
My 2 cents worth. Check to see if the Under hood light in the back is shorting you out. My car's previous owner had cut the wires and just tucked them up into the edge of the engine hood. My second problem was to back to electrical 101, I checked with a continuity tester to see if I was getting juice across the fuse at the fuse box. I found that what looked like a good fuse was not transmitting electricity, I changed the fuse and it has been working ever since.
timmy2 12-21-2011 05:25 PM
Originally Posted by LIVEVIL (Post 6443402)
Ok So I have figured out that it's the green wire with a yellow stripe that is grounding out someplace. Where, I have no clue.
Trace and replace... or repair. (Trace and replace just sounded better) :D
SweetWaterSurprise 12-21-2011 06:42 PM
Thanks. I know the fuses, stalk, and relay are good, they are all new. Its just a ground out someplace from that wire. I still need to check some other wires mentioned in this thread. I appreciate the help.
timmy2 12-21-2011 09:51 PM
LIVEVIL, What year is your car? Do you have the schematic wiring diagram?
The only green wire with yellow trace on my '78 to '83 diagram runs from fuse 6 bottom to the low beams.
Porsche Head 12-21-2011 11:27 PM
I had a similar issue when I got my car back from paint.
It was the way the bulbs were seating or the incorrect bulbs. Once sorted out there were actually no wiring issues.
As always not sure if that is your issue but hope it sheds some light :)
Three2 12-22-2011 11:48 AM
Similar Issue
Same twist - with turn signals not working but emergency working however I noticed that with the vehicle turned off that I can get a solid turn signal (ie no flash/blinking).
I was wondering if that points more towards the turn signal switch being bad?
arbita1 12-22-2011 12:18 PM
That's actually the parking light feature, and it works off a separate system. Maybe start a new post (not to hijack this one) and you can get some troubleshooting ideas.
Here are some quick ideas in the meantime:
1. Is Fuse No. 11 good? (I'm assuming you have an SC). A quick check is to see if your back up lights work as well.
2. If yes, is there power at connector no. 49 of the Turn Signal Relay socket?
3. If yes, then chances are the relay is bad and is the problem.
SweetWaterSurprise 12-23-2011 08:11 AM
My car is a 82. I am going to take out all my bulbs, check those connecttions and see if I am still blowing the fuse.
EmergencyLight 05-04-2012 03:47 PM
I've been having the exact same problem for a while now. I looked around for emergency lights but could only find stuff like this emergencylights.net
Can someone please help me find the right type of emergency light replacement?!
