Home of the Whopper
Question Installing cams
Hello!
I am putting my 2.2 back together and have finally reached the point where I need to time the cams. The manual says to rotate the cams until the punch mark is at the top. I just want to clarify what the punch mark is. I have letters punched in, and 180 degrees from them is a little divot punched in as well. I am thinking the manual is refering to the divot, but want to verify before proceeding. Little help!?
Thanks!
BK
Old 07-25-2001, 04:58 AM
Not Quite Banned
Thomas Owen's Avatar
Post
The cams on my 3.2 had the inscription '360' which was positioned at the top. My understanding is that the punch mark, if it exists, is the guide to always use.
Old 07-25-2001, 06:13 AM
Post
the keyways go to the top. that's the easy way. #1 and #4 pistons at TDC. put the distributor in now with the rotor pointing to #1 position so you don't screw up later and get it 180° off.
Old 07-25-2001, 07:16 AM
Home of the Whopper
Post
Gentlemen!
Thanks for the help! Hopefully this weekend will be vroom vroom time.
BK
Old 07-25-2001, 07:33 AM
