MFI warm up thermostat-how important??
I am installing a 2.7 MFI engine in my car. The MFI was formerly used in a race car, and has the warm up thermostat blocked off. I have all the parts to put it back on, but to use it would need to have a tube welded onto my SSI's before installation. Just how important is it to have this on a street car? I live in CA, where the temp rarely goes below freezing. BTW, this is a 10.3:1 dual-plugged s-cam motor. Thanks to any MFI gurus out there.
Steve in SLO
1971T R Grupper
2004 GT3
Buckets o' bicycles
Old 04-08-2002, 09:59 AM
Early_S_Man's Avatar
Porsche Crest
Steve,
Unless you don't consider good behavior and drivability during warmup important, put the thermostat back on!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-08-2002, 10:30 AM
Paul Thomas's Avatar
I have headers so i took mine off and have had no complaints. I also blocked off that rediculous stop solenoid.
Paul
My ignition is retarded.
Old 04-08-2002, 10:48 PM
jkeyzer's Avatar
Paul -
What did you replace the thermostat with? A bolt to push the lever all the way back? It is my understanding that the default (not pushed back) is full rich.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 04-08-2002, 11:00 PM
Warren Hall Student
Bobboloo's Avatar
On my heat exchangers the pipe that feeds the hose to the thermostat isn't even welded. It's just a snug fit. Then again maybe mine is a mod of earlier exchangers.
At any rate it should be an easy job. So why not do it.
As matter of fact I'd be willing to swap my 2.4T motor with yours as a kind gesture so you won't have to go to all the trouble.
Bobby
Old 04-09-2002, 01:38 AM
Bobby
The thing I like most about this board is that there's always someone willing to help me out.
Thanks all for the input...I think I will put the stuff back on.
Steve in SLO
1971T R Grupper
2004 GT3
Buckets o' bicycles
Old 04-09-2002, 07:42 AM
Stay away from my Member
campbellcj's Avatar
I'm kinda curious about this too...for a 'simplified' setup, i.e. a race car that is configured to only need to run well (or even properly) when warmed up, what would you need to do?
Specifically, what if you have headers instead of the stock left-side MFI heat exchanger with the preheat hose, you disconnect the enrichment and fuel squirter circuits and also the thermostat?
What configuration did the factory MFI racers use? Surely they didn't run full heat exchangers, solenoids, thermostats, squirters, air filter plenums and so forth...or did they?
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 04-10-2002, 12:17 AM
I did the exact same thing on my pump that Hanz at H&R Fuel injection does to pumps. I made a small plate to go over the hole and put a threaded rod in the middle to adjust in and out. As far as the stop solenoid, that thing is for emissions so that the ammount of fuel is cut back when you are deccelerating. The result on my car was that the motor would cut off because the fuel was cut back too much. Disconecting it was also recomended by Hanz.
The factory RSR's had a small switch on top where the thermostat was on the pump that one guy would hold full rich while someone else started the car and warmed it up.
Paul
Old 04-10-2002, 08:00 AM
304065's Avatar
Porsche Crest Thermostat with Headers
Chris:
Check the archives for a post by The Maestro, Roland Kunz. He goes into detail about how Porsche used a 12v bulb inside the thermostat inlet that would heat up as the engine ran.
My E race car has EVERYTHING stock: not only is it required by the rules, but you don't want to stall in the paddock.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-10-2002, 10:30 AM
