I've been following your build this winter. Looking good! I'm not sure what size the hoses are as I bought the whole "kit" from Instant-G. Instant-G 3.6 Liter Conversions Hopefully someone with more technical knowledge on this could chime in. I do vaguely remember reading about the sizing in another thread last year. Did you get the flange issue figured out yet? |
Yeas I think it will be solved, I'll get a pair of G50 flanges tomorrow. I will try to find the thread about hose size.
This winter I only have a few smaller projects to tackle.
First is my sticky/stiff throttle. I rebuilt the pedal cluster a few years ago so I know the bushings are still good but the throttle lever has been moving side to side last year and I figured it had weakened and may be bent. I bought a new one from our host and plan on reinforcing it in the weak areas. Well, I removed the lever this morning and was surprised to see no bending of metal. What happened was the weld had broken away between the shaft and the lever. It looks like the new one has more weld in that area so I should be fine. http://forums.pelicanparts.com/uploa...1425823919.jpg http://forums.pelicanparts.com/uploa...1425823989.jpg |
Tom, I have been watching your shift points with the video you shared with me (chasing the Atom). I am assuming you are running 8:31 and a stock gear-set. How much HP are you running with? Just trying to gauge things for my car's transmission ratio plans. IF you knew your rpm/speed at your up-shifts that would also help me.
http://forums.pelicanparts.com/uploa...1425920478.jpg |
Just about to embark on a 3.6 swap, and will use this for reference. Thanks for documenting!
Well, it's been 15 years since I bought my car and 6 years since the 3.6 conversion.
Still puts a smile on my face every time I drive it. My buddies and I had a great day with our wives hitting the back roads of "the Valley" yesterday. http://forums.pelicanparts.com/uploa...1533906215.jpg http://forums.pelicanparts.com/uploa...1533906288.jpg |
| All times are GMT -8. The time now is 08:25 AM. |
