An entire summer's work--ending in failure
Over the summer I had an issue where my car stopped being able to go into gear. 1st, 2nd, reverse--all grinded when I even attempted to shift. It got to the point where I would have to turn the car off at stop lights, put it into gear, then turn it back on so I could drive away. Long story short, all this culminated into me dropping the engine, replacing a whole bunch of parts that didn't need to be replaced, including the clutch plate, pressure plate, TOB, clutch fork, clutch cable, pedal cluster, starter, fuel injectors, so on and so on.<p>Now we come to tonight. I put the wheels of the car back on the ground for the first time in 5 months, start it up, and try to put it into gear.<p>Same. Exact. Thing. Happens.<p>It seems like the clutch cable is just 3-4 inches too long. I have it adjusted at this point to its furthest point of travel to tighten it and it still doesn't pull far enough to disengage the clutch. <p>Now, for your viewing pleasure, please enjoy this video of all my work for naught:
911 grinding gears after new clutch install - YouTube So, all this being said, is there any hope for me to change gears in this car again? |
clutch disc stuck to the flywheel? does it roll with the clutch pedal down? did you get a '75 cable instead of a '74? is the clutch cable tube in the tunnel loose? do you have the release fork engaged into the t/o bearing?
The fork is definitely engaged to the TOB. I spent a good hour making sure that happened when I was mating the engine back to the trans. Little bit of grease in the TOB channel and all. AFA the clutch cable, I bought the only one sold here at Pelican that would work-- the hooked end one. None of my clutch arm setup is original '74, so the hooked end cable is all I know to fit. But it just seems too long, as I can't get the full 25mm of travel that Bentley says the clutch cable needs. I'll check and see if the car rolls the clutch pedal pushed in.
Where is the Pedal Stop at on the floor board?
Please post a pic. |
Didi you carefully examine the fork, I had one crack and it would flex and do pretty much what you are describing.
Walk away take a break - this may require an engine/trans drop but it will be fixable with out too much hassle! You will taste victory , man over machine! :-) |
I've been there before, working on my car and it is frustrating! I'm not sure I can do more than offer moral support. My '74's original 915 had the single lever arm. It was super simple to set up. The late SC 915 on it now uses the omega spring set up, which is a bit more complicated, but still not terribly difficult. I'm not familiar w/the clutch cable w/the "hooked end". Is it possible to reposition the lever on the splined shaft one spline back to take up some of the slack?
could be a clevis pin at the pedal.......
how much movement are you getting with the cable? does your 911 have the horseshoe spring at the clutch lever? or was that only the later cars? it is easy to get the omega spring in wrong, it's gotta be loaded the right way..... |
So here's a little virtual tour of my pedal cluster, showing the pedal stop as well. Someone mentioned the clutch release fork having a crack--I replaced that as well (the old one was actually fine) so I know it's not cracked and bending. |
Could the problem be inside the trans? Did you open it up an have a look inside while you had it out ? You mention that you could kill the engine then get it into gear, could you then run the engine and let the clutch out as normal?
You will get this right...if it was man made it can be fixed...hang in there others here can help
You need a pedal stop or you will get the opposite effect. But we will take care of that later. Please ask a helper to do the same thing in the video as you record what is happening underneath. I know you did this, when you measured the gap at the clutch arm to the helper arm with the cable off, right? Do it again but this time see if there is any slack on the clutch arm. A buddy's 77 had a bit of slack giving us crazy readings. I turned the arm a bit forward and it solved the issue for him and we got the proper 1.0MM gap and 25MM throw after adjusting the pedal stop. He does not grind anymore. Think of it this way with the 1.0MM gap, there will be about 10MM play at the pedal at rest and moving forward before the fork catches the T/O bearing. Once it is properly adjusted, you should feel the clutch engage/release at midway point of the pedal throw. Jim |
Oh my Brother! I know what you mean. Don't let it beat you. Get some rest and be fresh to tackle it tomorrow. It will be worth it, I promise.
take the whole floorboard off to give the pedal more travel. I agree with others who think the cable is the wrong length or something like that.
Sounds like you have the wrong cable, but also, how much is the cable screwed in at the pedal? A couple turns makes a huge difference in travel.
I saw your other post about this, post a pic at the omega spring and the people with this type of setup should help. |
If you kept the old cable, try taking it to the local Porsche dealer to see if they can get a matching cable. Now that the new cable is installed it would be a pain to try and compare it to the old cable that used to work.
+1 on staying patient to prevail. Best wishes. |
| All times are GMT -8. The time now is 06:42 AM. |
