Question Piston question?
This is my first rebuild and I have a ton of books -- but I have a question. When installing the pistons, I believe the part of the piston which is concave is toward the top of the engine and the part which potrudes is towards the bottom. Is this correct? for both sides?
Old 03-30-2002, 08:06 AM
jabb's Avatar
What kind of Pistons..... CIS ??
If CIS the Flatter more Concave part is toward the Exhaust Valve
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 03-30-2002, 09:34 AM
or the lump goes to the left, as you look at it.
206 637 4071
Old 03-30-2002, 09:49 AM
Senior Member
Superman's Avatar
Yeah, they say the "flat" spot should fact the intake valve, which may be misleading. The small flat spot does indeed face the intake valve, which means the huge concave part faces the exhaust valve.
Mocha 1978 911SC. "Coco"
Old 03-30-2002, 12:04 PM
Author of "101 Projects"
Wayne 962's Avatar
Please don't take this the wrong way, but if you have to ask that question, then you don't have enough sources of information on rebuilding your engine. The answer to that question is in many books, including the Bentley manuals, and the factory manuals too (and in my book, but it's not out yet).
Stock up on information, as you cannot have enough when rebuilding your engine. As good as this board is, you have to know the right questions to ask to get the answers that you need...
-Wayne
Old 05-12-2002, 06:14 PM
