install case oil squirters: how
I am doing a rebuild on my 1970 911S. I have heard that in case of a upgrade to a 2.5 you should install the case oil squirters. Is there any point in doing so on a stock 2.2 S? Will tolerances in the P/C's which were based on higher temps be spoiled?
And if there is anypoint, what is involved in installing them.
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
Porsche started installing case squirters in the second year of 2.2 production so I guess they thought it was worther it. As far as doin git yourself I think you are best off getting a Porsche Machine shop to do the work as it involves driling holes in your case to hit an oil supply channel, and then installing and pegging the squirters.
Robert Currently Porsche less (but the wife has 2) |
Navin Johnson
What he said
I rebuillt my 2.0T into a 2.2S after I hand grenaded the motor on the track. Since I was goingthe S route I had the squirters installed whilst the case was being machined. This isnt a DIY project, the hole for the squirter has to be drill at an specific angle to intercept the oil passages
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Author of "101 Projects"
Agreed. Send it to Walt at Competition Engineering - he's the expert in these types of modifications to the early mag cases...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
