-   -   head stud fix question (http://forums.pelicanparts.com/porsche-911-technical-forum/646213-head-stud-fix-question.html)
advtracing 12-20-2011 05:37 PM
quickie for the experts , i have one head that has two studs that wont torque, is it possible to drop the engine , remove the heads on that side only remove the dodgie studs , add case savers to those 2 only with out splitting the engine completely ?
Joe Bob 12-20-2011 05:52 PM
No need to split the case to replace studs. BUT, you should do all of them.
john walker's workshop 12-20-2011 05:58 PM
yeah, when you go to reassemble that side, more will probably pull. you really need an alignment jig to drill and insert all 12 studs or they will porcupine and you will have trouble getting the head assembly back on and that may cause them to pull due to the uneven stress. normally this is done in a mill with the case split. yay! must be a 2.7 eh?
advtracing 12-20-2011 06:00 PM
how did you know .......the word i think i'm after is ....crap
larrym 12-20-2011 08:06 PM
old topic - addressed before - do a search on the engine forum
- short answer is you can now get a jig-drill kit from stomsky(?) that will let you do it without full teardown
in my case - i just sold the car
timmy2 12-20-2011 08:13 PM
Just find a good 3.0 or bigger and bolt it in. You'll probably spend less.
Looking at your garage it shouldn't be too difficult for you.
timmy2 12-20-2011 08:34 PM
Just saw this one listed in Portland, OR
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/646244-1979-porsche-911-sc-3-0l-complete-70k-mile-engine-3600-a.html
advtracing 12-20-2011 08:39 PM
perfectly good 2.7s , 10/10 compression 10/10 leak down , why would you replace just because 2 studs won't torque.
timmy2 12-20-2011 09:28 PM
Just an option, if the cost of doing the case (all new studs and certs) properly gets excessive. You did mention the word "Crap" earlier. :)
larrym 12-21-2011 07:31 PM
alternatives to fixin studs
if money is really no object ............ :D
- i have 2 - 3.2's in storage - both known good engines from '88 & '89 wrecks with carfaxes - plus a rebilt 915 - local pickup only zipcode 95635 and bring cash
and for $100/hr, i will help you install it if you bring your car
but. i suspect we would not be posting for stud fix solutions if we had lots of cash to throw around
- we'd just take the car to our local "best porsche fixer" & ask how much to write the check for
advtracing 12-21-2011 07:34 PM
hmmmm, i adult air fare (nz to usa ) 1 shipping sea freight car to usa and back, accom ....there's 10.5k
larrym 12-21-2011 07:36 PM
exactly the point
unless you can do it yourself - just pay the price to your l;ocal fixer
and enjoy the enhanced value of your car once it is back on the road - but the reality is we can spend $10K on an engine in a $15K car - and still only have a $15K car
I see worn out carreras with 250K on the odometer all the time at asking prices reflecting prices on cars with perfect rebuilt engines -
like the man says - if you have to ask the price - you can't afford the car
Schmierung 12-21-2011 08:18 PM
Sad to learn of your situation....At your point I would either :
1) spend significant money and repair present crankcase and consider upgrade pistons and cams.
2) Purchase a proven 3.0 (compression test and stud verification) used unit.
Both about the same price point.
larrym 12-22-2011 09:44 AM
stud fix tool for sale
fyi - in this month's Panorama - 2.7-3.0 stud fix tool for sale - $300 - contact Luis at ph 305-248-2175
quick - or pay more for a new one from Stomsky
