advtracing's Avatar
head stud fix question
quickie for the experts , i have one head that has two studs that wont torque, is it possible to drop the engine , remove the heads on that side only remove the dodgie studs , add case savers to those 2 only with out splitting the engine completely ?
"Funding my obsession one nut at a time"
Old 12-20-2011, 05:37 PM
RETIRED
Joe Bob's Avatar
No need to split the case to replace studs. BUT, you should do all of them.
2012 ML350 3.0 Turbo Diesel
Old 12-20-2011, 05:52 PM
yeah, when you go to reassemble that side, more will probably pull. you really need an alignment jig to drill and insert all 12 studs or they will porcupine and you will have trouble getting the head assembly back on and that may cause them to pull due to the uneven stress. normally this is done in a mill with the case split. yay! must be a 2.7 eh?
206 637 4071
Old 12-20-2011, 05:58 PM
advtracing's Avatar
how did you know .......the word i think i'm after is ....crap
Old 12-20-2011, 06:00 PM
ASE Master Tech - 35 yrs
larrym's Avatar
old topic - addressed before - do a search on the engine forum
- short answer is you can now get a jig-drill kit from stomsky(?) that will let you do it without full teardown
in my case - i just sold the car
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 12-20-2011, 08:06 PM
ROW '78 911 Targa
timmy2's Avatar
Just find a good 3.0 or bigger and bolt it in. You'll probably spend less.
Looking at your garage it shouldn't be too difficult for you.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-20-2011, 08:13 PM
ROW '78 911 Targa
timmy2's Avatar
Just saw this one listed in Portland, OR
1979 Porsche 911 SC 3.0L Complete 70K mile Engine $3600
Dennis
Old 12-20-2011, 08:34 PM
advtracing's Avatar
perfectly good 2.7s , 10/10 compression 10/10 leak down , why would you replace just because 2 studs won't torque.
Old 12-20-2011, 08:39 PM
ROW '78 911 Targa
timmy2's Avatar
Just an option, if the cost of doing the case (all new studs and certs) properly gets excessive. You did mention the word "Crap" earlier.
Dennis
Old 12-20-2011, 09:28 PM
larrym's Avatar
Talking alternatives to fixin studs
if money is really no object ............
- i have 2 - 3.2's in storage - both known good engines from '88 & '89 wrecks with carfaxes - plus a rebilt 915 - local pickup only zipcode 95635 and bring cash
and for $100/hr, i will help you install it if you bring your car
but. i suspect we would not be posting for stud fix solutions if we had lots of cash to throw around
- we'd just take the car to our local "best porsche fixer" & ask how much to write the check for
Old 12-21-2011, 07:31 PM
advtracing's Avatar
hmmmm, i adult air fare (nz to usa ) 1 shipping sea freight car to usa and back, accom ....there's 10.5k
Old 12-21-2011, 07:34 PM
larrym's Avatar
exactly the point
unless you can do it yourself - just pay the price to your l;ocal fixer
and enjoy the enhanced value of your car once it is back on the road - but the reality is we can spend $10K on an engine in a $15K car - and still only have a $15K car
I see worn out carreras with 250K on the odometer all the time at asking prices reflecting prices on cars with perfect rebuilt engines -
like the man says - if you have to ask the price - you can't afford the car
Old 12-21-2011, 07:36 PM
Sad to learn of your situation....At your point I would either :
1) spend significant money and repair present crankcase and consider upgrade pistons and cams.
2) Purchase a proven 3.0 (compression test and stud verification) used unit.
Both about the same price point.
Old 12-21-2011, 08:18 PM
larrym's Avatar
Exclamation stud fix tool for sale
fyi - in this month's Panorama - 2.7-3.0 stud fix tool for sale - $300 - contact Luis at ph 305-248-2175
quick - or pay more for a new one from Stomsky
Old 12-22-2011, 09:44 AM
