Quick 3.6L fuel question
I'm have a fuel issue with my 3.6L. I haven't driven it for quite some time (3 years or so)
The car will start and run for a second or so if I squirt gas in the intake, but it won't stay running.
I've hot-wired the fuel pump, and I can hear it running.
I removed the line at the fuel filter, but I get nothing with the pump running; my possibilties would then be
a) fuel pump is running but not pumping (?)
b) fuel lines are clogged
c) ________________?
Old 12-11-2011, 01:03 PM
Bill Verburg's Avatar
Just a guess, water in the system from the E10 gas we all are using, temp change causes the alcohol to separate out of the gas, it then absorbs water. I have huge issues w/ this unless I uses a gas stabilizer
Bill Verburg
Old 12-12-2011, 07:31 AM
Tom '74 911's Avatar
I think you're on the right track. If you're not getting fuel in the engine bay (assuming that's where your filter is still located) that obviously something in the system is either blocked or not working. . . sorry I don't have the magic bullet for you, looks like you need to do some more investigating. . .
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 12-12-2011, 07:50 AM
Turns out it was the fuel pump. Swapped in a new one and it fired right up.
Now I have a leak in one of the lines near the tank. If it's not one thing it's another....
Old 12-24-2011, 03:10 PM
