OnNorthFace
Porsche Crest Installing new Blaupunkt in '85 911
I will probably get some help to install a new Blaupunkt Toronto 410 BT in my '85 - but does anyone happen to know what the right wiring harness is? I have looked all over eBay but no-one explicitly lists the harnesses as fitting this deck. The plugs look the same as many Blaupunkts (two sets of 8 - one clips in the center of the plug and the other at the bottom)...
Any clues?
Thanks.
Old 12-25-2011, 01:21 PM
The guys at Crutchfield .com maybe able to help.
Old 12-25-2011, 01:58 PM
one of gods prototypes
bell's Avatar
do you need the harness which plugs into the radio? if so post a pic of the back of your radio...
Brought to you by Carl's Jr.
Old 12-25-2011, 06:14 PM
OnNorthFace
Porsche Crest This is the rear of the stereo...
Yes - exactly - I need the harness that plugs into the rear of the stereo....thanks.
Old 12-26-2011, 02:53 PM
scottb's Avatar
These may be the harnesses you need: Plugs - SW Stereo Specialists
If those aren't the ones, then give SW Stereo a call and they'll likely be able to hook you up (figuratively and literally).
1984 Targa
Old 12-26-2011, 03:00 PM
OnNorthFace
Porsche Crest
Thanks very much. I will follow up with them
Old 12-26-2011, 03:28 PM
bell's Avatar
the top one is speaker out, the middle one is power/grounds, the bottom are for preamp out to external amp.
both the speaker plug and power plug should be the same as any vw or mercedes up through the 90's.
this is what you need, not affiliated with seller.....just as example....
BEST KIT BHO1784 MERCEDES 96-02 FACTORY RADIO HARNESS | eBay
be aware
the ign/battery wires may be reversed (no big deal, won't hold memory if so so just swap them)
and the blue power antenna wires you'll need to check with a test light to see which turns off with the tuner....
the speaker wires should be dead on.....
Old 12-26-2011, 05:52 PM
jkevinc's Avatar
How did it go and how do you like it?
Hi. Curious how the rest of you installation progressed and if you like the Toronto 410 BT. Also, did you pick up a harness?
I was considering ordering one off of ebay since it does not seem to be all that available domestically. Primary reason for selecting this unit is that is does not look garish as so many head units do.
Thanks,
John
1989 911 - Stone Grey Metallic
Old 01-24-2012, 02:42 PM
Tags
blaupunkt , install stereo
