won't go into 2nd gear
All other gears seem fine. It bucked a little in second, so I threw it in neutral, then it wouldn't go back into second. It physically won't go. It does have a short shift kit installed. Ohh and it is a 81 SC. I just replaced the fluid about 300 miles ago with swepco.
Where should I start here? Thanks, John |
shift coupler, under panel in front of rear seats
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Hopefully it's just your linkage. Not sure how to best describe it but getting into second is the furthest your shift linkage needs to articulate so it's sensitive to good adjustment. I hear the short shift kit makes it seem even worse since you have less leverage. I would make sure your linkage is properly adjusted before thinking about breaking into the box.
may have blown the teeth off the syncro hub (dog tooth ring). then the syncro expands and blocks the shift sleeve. check the drainplug magnet for little teeth and don't drive it until you determine this is not the problem. a brake band, stop dog, anchor block and the syncro itself can go through gears and that's not a good thing.
Member 911 Anonymous
+1 check the drain plug for bits and pieces.
I assume you had no issues prior to lube change, if drain plug comes off clean then consider going back to 80w90 weight conventional gear lube. If you have LSD then with additive. Hope you don't find this:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
If not the coupler, could it be the the fork under the cover?
72 911 Although it is done at the moment, it will never be finished. |
Ohh man.....That is what I found on the drain plug when I changed it to swepco! They weren't quite as big as those pieces, but they were there......
That sucks.
they don't all go to the magnet. probably more inside somewhere. pull off the shift guide plate and see if the fork is loose, as long as you have the oil drained. 2nd gear dog teeth are pointed, like the roof of a house. 1st gear teeth are angled like a lean-to.
Oh no, sorry to see that.
+1 take a look at the side access panel and post a pic of the components. So you changed to Swepco from what ever it was in there and found debris like my pic? Did you find the larger peices as well? Did you have issues with second prior to Change out of the gear lube? In anycase, post a pic of the components, we can better tell where to go from there. Again sorry to see that pic.
Well I decided I was above my skill level here. I have my car with professionals now (flat6pac and gary fairbanks in CT). I did lose 5th gear today too trying to get it to the shop. It's worse than I thought!
Damn, while you are in there have them clean and lube the T/O bearing and Guide Tube.
Also have them check out the Fork for wear and potential fracture.
John, got the engine and trans out today and separated. The accumulator has gas coming out the bottom connection, needs replacing. The clutch is in the 7.2+mm rang out of 8 so its getting down.
Bruce ![]() ![]() ![]()
Just came through Nash county today on the way to CT.
Would have hauled it up there N/C.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I have the trans stripped of excess weight, now I can make the 150# for UPS. I talked to Gary Fairbanks Friday and he said ship it up. John will be happy to get it back.
Stripped, reinforced, belted down and shrink wrapped for the trip to Conn. Bruce ![]()
Awesome Bruce! Thank you so much for your help with this! I feel pretty lucky to live close enough to have you work on my car!
John, looks like you need paint and peace signs to make it look the age of Aquarius...
Bruce Gary is suposed to have the trans on Wednesday. |
Gary will have the trans today. I m putting the better clutch on the flywheel, 7.9+.
I checked the distributor to make sure its advancing properly and found all kinds of dust in the distributor. Dust looks red, closer look there is a line in the cap from the rotor coming apart. The end of the rotor is gone. Bruce ![]()
