Grill restoration
I recently purchased an aluminum rear grill from a 74. It's in overall decent shape. The black anodize has worn or faded almost all the way off. I think I will just hit it with some rattle can satin black to mimic the anodize.
The strakes are all staright and true and the mesh is in good shape baring one small hole taht is only visible from the back.
My issue is when I removed the grill from the deck two of the mounting studs broke. Has anyone addressed this issue? How have you replaced the studs?
Thanks for any input.
Old 12-01-2011, 05:14 AM
tobluforu's Avatar
I have two that broke on mine and it still attaches just fine, but mine is a 72 and different. I also had mine PC.
Old 12-01-2011, 06:14 AM
ROW '78 911 Targa
timmy2's Avatar
Carefully drill and tap a hole for a bolt the same size as the old stud. Cut the end off the bolt and file it to make a new stud. Or just install a stud if you have one. I'd use red locktite.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-01-2011, 09:57 AM
Timmy2,
I'm a little confused by your recomendation. Do you mean to tap the frame and screw a bolt into it?
Old 12-02-2011, 04:37 AM
Any thoughts on how to fix this issue? If I were to disassemble where can I get rivets to put it back together?
Old 12-05-2011, 11:51 AM
I have replaced all studs on my grill by taking the grill apart. I cut off the rivets on the backside of the grill, took it apart, replaced the studs and glued back together the 2 parts with metal epoxy glue. Has hold for 6 years now and looks original from the outside.
'71 911 T
Original Burgundy
Old 12-05-2011, 01:32 PM
Thanks Hessel 1974,
What epoxy did you ue?
Old 12-05-2011, 04:00 PM
Registered speed offender
78SCRSMAN's Avatar
Are we still on this? Gee Whiz!
1) drill out rivets
2) replace broken studs with simple short studs M6 I believe
3) buy rivet tool and assortment of rivets from Home Depot (buy aluminum rivets)
4) re-rivet back together
5) take repaired grill to annodizer to have old annodizing removed and re-annodized.
6) if you have more questions... don't ask, send it to me and I'll do the above for $200
Old 12-06-2011, 11:44 AM
I rattle canned mine, you can take a look at in on Saturday. I'm pretty pleased with the way it turned out...
Old 12-20-2011, 06:12 AM
Hi Driver X
Can;t wait to see it. See you saturday.
Old 12-20-2011, 12:24 PM
Which of these two photos is correct for a 74 2.7 badge aluminum back ground or painted?
The second question, is the 2.7 solid aluminum or just an electroplate? I am concenrd about cleaning and maybe a light polishing taking the finishe off.
Thanks again for the help.
DR.
Old 12-26-2011, 07:54 AM
In the,literature that I have, the background is painted. FWIW
Old 12-26-2011, 02:09 PM
Driver X,
I like how you painted yours I think it looks great. I am leaning toward painting the back ground. What literature do you have? I picked up the Rustoleum yetserday. Oh Tony did call but my ringer was off. Also my wife did'nt shoot me when I put the grill in the dish washer. Whew got lucky on that one.
Old 12-28-2011, 04:06 AM
