84 Rear View Mirror Fell Off --- Help
Any one have a good fix for this one??
1st the little dim lever on the bottom broke a few weeks ago and now when I was cleaning the inside of the wind screen and bumped it the entire mirror fell off.
I tried some Locktite instant super type glue I had on hand but it would not adhere. Porsche must have uses a certain type of adhesive for it to hold on the past 27 years, anyone know what to use?
This must be a common problem as these cars get older.
Thanks ... Rich
crude rudy
'84 cab
'14 ZX-14R
Old 12-27-2011, 01:00 PM
There are specific windscreen mirror adhesives, Loctite make a kit. I found these eventually gave way, however. After a few failures I found the best solution was to go to a replacement windscreen installer. They have UV activated adhesives which hold for years, and the cost is minimal
Scott
Old 12-27-2011, 01:06 PM
schumicat's Avatar
any auto parts store will have rear view mirror adhesive which will hold for many years if you follow the directions.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-27-2011, 01:21 PM
Hi
Targa Me's Avatar
mine fell off over a year ago and i just never put it back on. i just learned to look out the side mirrors.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 12-27-2011, 01:55 PM
Super Glue did the trick for me. Just need to hold it in place for a couple of minutes.
87 blk coupe
11 GTI
Old 12-27-2011, 02:20 PM
There is no substitute
I just did mine a few weeks ago.. You need to remove the button, clean it good and score it with a blade or screw driver, and clean the glass very well. The rearview mirror adhesive didn't work for me, I then tried some good 2 part epoxy glue, and it worked like a charm. Mix the epoxy, don't use too much.. hold the button in place with a piece of duct tape and let dry for a few hours, then you're ready to install the rearview mirror. Hope this helped.
The Hacker
96 C4S
97 C2 (Gone, but not forgotten
Old 12-27-2011, 07:26 PM
Walt Fricke's Avatar
Scott - what a good idea. UV actuation, just like my dentist uses on the fillings these days.
Old 12-27-2011, 07:34 PM
rgrimm's Avatar
Have you checked with a windshield glass shop?
I had the mirror fall off my daily driver. A body shop I've used over the years gave me "a referral" to a shop down the street. I pulled in, we had a good conversation while he worked and when I tried to pay him, he refused to take any money!
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 12-28-2011, 08:21 PM
