-   -   Can you identify this for me? Wire into trans- (http://forums.pelicanparts.com/porsche-911-technical-forum/647382-can-you-identify-me-wire-into-trans.html)
gsxrken 12-27-2011 01:44 PM
Hi- doing my first engine drop and I have a small wire going into the RH side of my transaxle, right above the CV joint flange. It seems to be retained by a small bolt that has a hairpin looking piece that holds a cover.
What is it? I assume it need to be detached before I start lowering things... Do I remove that bolt and fish out the wire or cable? Seemed like a good time for a break so I thought I'd stop and post it up. Thanks
Oh, BTW, 1986 911 turbo.
JP911 12-27-2011 01:46 PM
Speedometer sender. You can remove from trans or disconnect the wires in the tunnel.
E Sully 12-27-2011 01:59 PM
Be careful not to damage it when removing.
Pelican Parts - Product Information: 911-606-209-01-M100
timmy2 12-27-2011 02:05 PM
If you are dropping the engine and tranny as an assembly then you will need to disconnect and label the 2 wires from this cable in the tunnel when you disconnect your shift coupler.
I would leave the assembly in the tranny unless your speedo doesn't work.
gsxrken 12-27-2011 02:12 PM
Fantastic- will disconnect in tunnel. Thanks gentlemen!
fred cook 12-27-2011 02:15 PM
Speedo wire or .....
On a 73T, it is more likely the backup light wire. I believe the early cars had a mechanical speedo, did they not? You still want to be careful with it.
fred cook 12-27-2011 02:17 PM
Oops my bad.....
Saw the earlier car and mentally put it to the wrong post. Yep, speedo wires.
boyt911sc 12-27-2011 09:33 PM
Interchangeable connections........
The two (2) brown wires from the speed sensor are interchangeable. They could go either way so long they are hook up separately to the connectors. But labeling them is a prudent practice.
Tony
