Anyway, lets just agree to disagree. The engine has some properties of both 2 and 4 stroke piston engines but is so different as to make comparison useless. |
What makes a two-stroke cycle piston engine a two-stroke cycle piston engine is the two component cycle. The Wankel cycle and two-stroke cycle piston engine are very different in regards to their cycles. The RX-7 engine is no way like a two-stroke piston engine. At least the Otto cycle of the typical four stroke engine and the Wankel cycle of the Mazda Rotary have the same four components. Scott |
ok, so if i have fuel, spark and compression, why doesnt it start????????
If the timing is somehow "taken" from the mainshaft then rotor position in relation to the mainshaft will be very critical. Ignition will fire for every 360 degree rotation of the mainshaft. |
When he put the wankle together did he do it in a pentagram with 5 black candles at each point? You would probably have better luck over at Miata.net than here. I know that Miatas don't have rotaries, but there are lots of rotary fans there. I'm sure there may be a Rotary/RX-7 forum too, just not sure if it would be full of idiot ricers or knowledgeable helpful folks or not. |
Having rebuilt many!!!!!! my suggestion is to make sure you have the timing set up correctly (markings on the distributer/crank angle sensor at the end with the cog drIve, you will need to read the shop manual and/or google) Once you are sure of your work the car with compression, spark, fuel and correct timing will more then likely need to be tow started! (yes, painful I know!) once you manage to start the car let it run for about half an hour to let everything bed in correctly and you should be able to start it off the key from then on. Now, what I am interested in is how you managed to do a compression test on the engine as it is not done in the same manner as a piston engine......., not that I'm doubting your ability but you may find you don't have the compression that you think you do.......(Google will help with this too!!) Good luck! and let me know how you go. |
. . . should we count the crank rev's? meh - I suppose that we should all just agree to be disagreeable. :cool: |
Yes, a turbofan engine has the same four components in its Brayton cycle as does an Otto cycle piston engine. But, in a turbofan engine, the combustion takes place at constant pressure, rather than with the Otto cycle and Wankel cycle, which are constant volume. The difference here is that the two-stroke piston engine uses the two-stroke cycle which is a two component cycle. A Wankel cycle engine is not a two stroke engine or anything like a two-stroke engine and is more akin to an Otto cycle engine because it has the same four components in its cycle as the Otto cycle engine. Scott |
this may be OT but I was reading re. Otto cycle engines because of this thread and investigated the Atkinson cycle engine because I have one now in a Lexus ct200 (wife car). Turns out the Atkinson cycle engine is becoming somewhat common in hybrids. The Atkinson cycle engine is ~10% more efficient at the expense of hp/cid, this is made up with battery power when needed.
scott |
As long as it quits over an empty field where nobody gets hurt, it's all good..
OK, who cares how many "cycles" the engine has?
The facts are it has intake, compression, power, and exhaust areas, and that it has one power "stroke" per lobe per shaft revolution. |
Wankel Rotary w/base/Atkinson/Miller cycle modes.
Wankel Rotary ~18:1 base/native compression ratio, DFI plus intercooled SuperCharging, linearly modulateable SC. Triple intake ports with the second and third displaced rotationally and having electromagnetically controlled valve close/open capability. Rotational displacement of the 2nd intake port/valve provides for CR of ~15:1, 3rd valve opening limits CR to <10:1. "Otto" mode, idle and/or simple cruise, no boost and the axillary inlet ports are closed, ~18:1 compression ratio. Moderate acceleration, engine load, loading and the 2nd intake valve opens resulting in ~12:1 effective CR, no boost, Atkinson cycle. HARD acceleration, HIGH engine loads/loading, 2nd & 3rd intake ports now open, engine's "base" compression ratio <10:1, Miller cycle. "Measured"/Metered boost as a function of gas pedal position beyond 50%. Engine "base" effective CR now <10:1, SC boost raises effective CR in a linear fashion. Positive displacement variable speed SC. SC is driven via a PSD(CVT) summing machine, engine drive as one input, synchronous multiphase AC motor as the second input. Variable frequency inverter drive allows linear control of boost level in depended of engine RPM. SC "meters" intake airflow, NO throttle plate. |
Anyway, you don't need to tell me that a Wankle is not a 2-stroke engine. Oh, and glad to see you finally get this all straight. :cool: Happy new year. |
4-cycle/stroke engine has ONE power event for each 720 degrees of power producing mechaniism rotation.
2-cycle/stroke engine has ONE power event for each 360 degrees of power producing mechanism rotation. Wankel has ONE power event for each 120 degrees of power producing mechanism rotation. Wankel = 0.6666-cycle/stroke...??? |
Well, I was going to say something about compression (or power) being a process, and the whole suck squeeze bang blow thing being a cycle but I just don't care anymore. :(
The OP wanted to know how a rotary engine worked and Quicksilvers animated post shows with great efficiency how it does. It cannot be compared to a piston engine just like it can't be compared to a turbine. It makes power in a different way than either one. They all have a form of intake, compression, ignition and exhaust but they all do them very differently. It's not a two stroke, four stroke or even .666 stroke; it's a rotary.
A bit different way to think of the rotary is to remember the 'combustion volume' smoothly sweeps all the way around the face of the ellipse... So it's really close to a turbine, just viewed at 90 degrees.
In other words, in a turbine the combustion process is axial to the output rotation. The rotary has the same smooth 'blending' of the combustion events, just radial to the rotation. Rotarys are inefficient due to the large surface area of the 'combustion chamber'. Thermal coatings help. Mazda has played with ceramic inserts for years. Amusing though is that all the surface area actually makes the rotary really nice to use with hydrogen as a fuel. I'd like to think that's mazdas endgame for keeping the design 'alive'. t |
| All times are GMT -8. The time now is 05:28 PM. |
