LinkBack | Thread Tools | Rate Thread |
I came across the following data when trouble shooting the autoheat in my SC.
The Porsche Manual for the SC refers to the mirror sensor as being "1.5kOhm at room temperature". Bentley gives the value as 1.9k Ohm at 20C(69F). The heat exchanger sensor is listed by Bentley at 1.7K Ohm at 20C (69F). The Porsche Manual lists the value for the exchanger sensor at 135 Ohm at 100C (212F). It may be possible to find standard thermistors that are close to these values.
Jim M. 79 911SC |
Mark.
Mark - New Glarus, WI |
Sorry to hear about the sensor. I figured it was a long shot but worth checking. JR Last edited by javadog; 01-02-2012 at 08:52 AM.. |
After reading the posts today I tackled my inoperative auto heat this afternoon (Federal holiday). 40 degrees today in the MD/ DC area, so great for getting heat to work.
My passenger seat came out very easily, although watch for the backing pates to fall to the floor. I used a magnet want to fish them out. Turns out the clevis on the front end of the rod was broken. Broken because the cables were very stiff. I confirmed this by moving he cable belcarank manually. I was able to tie wrap the clevis end so that it stayed (mostly) on the ball stud long enough for the heat to come on while holding the clevis against the belcrank connected to the heater cables. Next, I got the car up on a lift and sprayed some PB Blaster on the cable ends under the car and worked the cable back and forth some as best I could. I need to clean and or replace the cables, but at least I now know the auto heat unit is function. On the way home from the lift, auto heat worked, including the max "shoe melt" setting. I'm pretty sure the rod clevis will pop off again soon, so I'll get a couple of those too and leave teh right seat out for now. Thanks to all for the advice.
'86 Porsche 928S '87 Porsche 930 Coupe |
Auto heat 1987 930
![]() Forgot to include a picture for reference. CV
