-   -   Separating 915 from Engine (http://forums.pelicanparts.com/porsche-911-technical-forum/647931-separating-915-engine.html)
Targa Me 12-30-2011 12:28 PM
Hello All. SmileWavy
I've got my 3.2 out and I'm trying to separate the trans from the engine and it's not budging. I've got it split just a little bit but not much. :(
I had this same trouble last time (100k ago) but I don't seem to remember it being this much trouble.
Do you guys have any tricks I need to know about ? :confused:
Frustrated. :mad:
jklaspok 12-30-2011 12:36 PM
This thread http://forums.pelicanparts.com/porsche-911-technical-forum/29497-1980-3-0-seperating-trans-eng-probs.html I believe explains the trick you are looking for. It worked for me.
j911brick 12-30-2011 12:37 PM
Did you take the arm off the bottom?
Targa Me 12-30-2011 12:50 PM
Ok, I got it.
I forgot to take the arm off the bottom. Once I did that all was good.
Thanks Pelicans !
jklaspok 12-30-2011 12:53 PM
Yes. I'm in the process of replacing the clutch and performing general maintenance. That includes removing and lubing the clutch release shaft, and replacing the seals. The release fork is connected to the TO bearing. Remove the positioning lever and the tranny should slide out with ease.
DRACO A5OG 12-31-2011 11:06 AM
Damn L,
Call me next time, I will be up to help :D
J
