-   -   What am I doing wrong - rear bumper guard removal (http://forums.pelicanparts.com/porsche-911-technical-forum/648218-what-am-i-doing-wrong-rear-bumper-guard-removal.html)
tdskip 01-01-2012 09:21 AM
OK guys - once the nuts from these bolts are removed it should just pop off, right?
http://i207.photobucket.com/albums/b...idebumper1.jpg
http://i207.photobucket.com/albums/b...sidebumper.jpg
juanbenae 01-01-2012 09:30 AM
the paint holds them in place often. put the nuts back on the bolts and hammer with a block of wood. it will more than likely remove portions of the bumper paint.
vesnyder 01-01-2012 09:33 AM
I just removed mine with the bumper off of the car. It took several wacks with a BFH and it cam right off. Keep hitting - they will eventually loosen and fall off. Be careful to use a rubber mallet or the wooden end of the hammer so as not to damage the threads.
blue82coupe 01-01-2012 09:34 AM
I would say a couple of taps with a brass hammer or deadblow hammer should work..
ivangene 01-01-2012 09:37 AM
took mine off last week...fell off
so what's going on as replacements?
I was actually thinking of a vinyl sticker in the shape of the outline in black (my car also Guards red) - then I read about the ends of the rubber strip coming loose and I thought I should make some sort of "cap" to hold those down....
what's your plan?
ivangene 01-01-2012 09:38 AM
OH..... easy way to get them off...once bolts are out...SIT ON THEM
tdskip 01-01-2012 04:06 PM
Thanks guys - rapped on it a wood block and a hammer and that worked.
I was surprised by how heavy they are.
DRACO A5OG 01-01-2012 04:37 PM
Before you put them back on check to see if you have sag on any of them, if so tweeking them a bit will help form to the valance better and restrict debris getting up it.
Yes those suckers are indeed heavy, they have a steel/metal frame inside them.
ivangene 01-01-2012 04:43 PM
has anyone ever cut a few inches off one in an effort to lighten it and yet keep the original look?
DRACO A5OG 01-01-2012 04:49 PM
From the bottom or sides? I guess after cutting you can use a hot iron to smooth it out???
But how to deal with the metal frame? One of mine rusted, I removed all the rusted metal and filled with sealant then used my heat gun to form the bottom to seal up to my valance like the good one.
ivangene 01-01-2012 04:56 PM
no... length (away from bumper) same foot print just remove all the part that sticks out towards the car behind you
DRACO A5OG 01-01-2012 05:29 PM
Oh I see, hmm, I have a spare, maybe it is time to disect???
ivangene 01-01-2012 05:35 PM
mine are MINTY - so I wont experiment but I was just trying to come up with an easy lightweight version that kept the hold down bits for the rubber trim...as of right now I am considering a sticker...and some sort of clamp for the rubber
There is a guy offering machined plastic ones but I never got a firm price and then didnt care much for the look anyhow....not sure where I will end up but hope its not the ghetto :p
Mitch Leland 01-01-2012 05:55 PM
+1 on the weight of the bumper guards, then you add the weight of the muffler heat shield it really adds up. I left the muffler heat shield off when I installed my M&K muffler. Too bad there's not a good source for the European bumperettes.... that won't break the bank.
ivangene 01-01-2012 05:57 PM
WOW - muffler = big weight.... I pulled mine off and had a tough time putting it back on...but no muffler is pretty loud :p
dw1 01-01-2012 06:17 PM
There are quite a few good ideas in the "official modified bumper thread".
http://forums.pelicanparts.com/porsche-911-technical-forum/349342-official-modified-bumpers-thread.html
While I left them off completely (my car is shown in p. 7 of that thread), lightweight (hollow) copies made from wood, primed and painted semi-gloss black is an option I considered.
scott87 12-17-2012 09:49 AM
1987 Carrera Bumper Guards
I want to change the bumper guards ( the fat ones) off my 1987 Carrera to the narrow Euro bumper guards.
I needs some help!!!
- First - what bumper guards do I actually need?
Is it the bumper guards off a 1974 911 - part # 911-505-342-00
or a different bumper guard part # 930-505-031.00.
I am getting conflicting information on what bumber guards I actually need.
Has anyone actually done this project on a 1987-1989 Carrera?
I would very much appreciate some advice. Thanks!!!
sm70911 12-17-2012 10:20 AM
You need the 930 PN. They fit the Carrera valance
I did the project on my 86 Carrera and it looks great. You wil be left with two holes on either side. You can either use plastic caps from home depot or aluminum weld and re paint.
I got euro Carrera bumper guards in the UK for about $80.
Porchcar guy 12-17-2012 10:49 AM
Baby Bumper guards
http://forums.pelicanparts.com/uploa...1355773775.jpg
Custom made by a guy in Texas...same shape, holes etc but only about 2-3" thick...I love the look ! License frame lights
scott87 12-17-2012 11:25 AM
1987 bumper guards
Thanks sm70911 - How difficult was it to drill into the bumper?
Did you use a regular drill and bit ?
I actually tried to see how difficult it would be and it seems like it would be impossible to get through the bumper.
Any suggestions?
Thanks!
