GothingNC's Avatar
Thumbs up Now I have heat and my idle is better
I was working on replacing the broken heater cable and noticed the heater hoses to the flapper boxes had some serious issues.
Replaced them the the 2 1/2 inch aircraft hose and during this mornings 20 degree drive I was roasting.
Also, I been having an issue with the idle sometimes occilating while sitting at a light and then a few minutes later it would be fine.
I wonder if the heat escaping from the hoses on the drivers side was affecting the 02 system and vacuum hoses that travle overhead,
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 01-03-2012, 05:36 AM
ivangene's Avatar
Damn John...got all the miles out of that hose!!
I dont see how this would effect running.....maybe you bumped the ground strap and it makes contact now? Nice to have heat
Ed M
86' Coupe
Old 01-03-2012, 05:42 AM
GothingNC's Avatar
Maybe the CIS is enjoying the fridid cold dry air.
Old hoses were only 8 years old.
John D.
2012 Golf TDI
Old 01-03-2012, 05:49 AM
El Duderino
tirwin's Avatar
Hmmm... Very interesting and glad you got your problem solved. Funny how one thing can affect another.
BTW, where did you pick up the aircraft hose? From our host?
ivangene's Avatar
If these are where I think they are (near clutch) then they are (or should be) fairly isolated from the motor intake - but yea...cool air = better...but that is the opposite of your findings...
hard to believe the motor area would get warm sitting at a light....there is a large hole above it
I like that it runs better....how about? bumped the O2 sensor and knocked the soot off it
Ed M
86' Coupe
Old 01-03-2012, 05:54 AM
GothingNC's Avatar
Here
SCAT AIRCRAFT DUCTING from Aircraft Spruce
John D.
2012 Golf TDI
GothingNC's Avatar
Ed,
I have the car set up rinning with the o2 sensor disconnected.
Maybe the disconnected plug end sitting on the cooling tin was getting hot.
John D.
2012 Golf TDI
Old 01-03-2012, 05:58 AM
ivangene's Avatar
If that's the case, I am pulling mine out and setting it on something hot...I have been chasing a "surging" issue for a couple months :grr:
Ed M
86' Coupe
Old 01-03-2012, 06:01 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Thanks for posting the link, I want swap my hoses soon
'85 Carrera Targa
PCA/POC
Old 01-03-2012, 11:35 AM
GothingNC's Avatar
Wear some good goggles.
All sorts of crud fell onto my face when I pulled off the old hoses.
The ends of the flapper boxes had a bit of rust but there is enough metal to hold the new hoses for a while.
Also, the spring wire in the new hoses does a great job keeping pressure on the connections.
John D.
2012 Golf TDI
Old 01-03-2012, 11:40 AM
