I read both of your posts and think there must be some easy answer....
you checked spark? you checked fuel? there isnt anything left so it comes down to how did you check spark and fuel to be 100% sure |
I think i found the issue. Looks like a broken coil cable to distributor cap. I've attached pics. I didn't get to test spark. will do that tomorrow but fairly sure i need to change cables. since I'm at it I'll change caps, rotor, coil and all cables.
http://forums.pelicanparts.com/uploa...1331509483.jpg |
Thanks Ed!!. will post new findings after i make changes. I had a helper with me who confirmed spark but don't believe that was the case. Guess I was in panic mode..
| All times are GMT -8. The time now is 11:04 PM. |
