Intermittent shifter vibration
Hi,
I have an 89 Cab with about 115K. Drives and shifts fine but I am starting to get a vibration in the shifter around 3K RPM. If I put my hand on the shifter the vibration and metallic sound stops. From searching I am thinking it is the shift/coupler bushing since I think it is still the original. My real question is does that seem logical or is it a symptom of something else that I am missing.
1989 Cabriolet
1970 911E Sold
Old 01-09-2012, 04:30 AM
Originally Posted by david482 View Post
Hi,
Is it just in a certain gear? If so, shift coupler needs to be slightly tweaked to relieve pressure of riding against the gate in that gear. That was my problem, In 4th gear starting at about 3K rpm.
hope this helps,
Bill
Old 01-09-2012, 04:40 AM
Seems to happen most in 4th as well. Thanks for the info
1989 Cabriolet
1970 911E Sold
Old 01-09-2012, 05:10 AM
Dave Colangelo's Avatar
Regardless of the cause of the issue if your bushings are original you should replace them. I would be willing to bet if they were that old they could be part of the issue. The job is easy and can be a big improvement on shifting.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 01-09-2012, 07:57 AM
I was thinking that replacing was probably the best option, now I just have to figure out which replacement to order.
1989 Cabriolet
1970 911E Sold
Old 01-09-2012, 08:25 AM
Any suggestions - it seems that the OEM kit has everything I would need, the WEVO looks cool but a bit overkill for what I need and I am not looking to add more noise.
1989 Cabriolet
1970 911E Sold
Old 01-09-2012, 10:13 AM
