Carrera and Stone Guard removal
All,
I need to give the car a very thorough exterior detail over the next couple of days. The stone guards came off though left some tacky residue. I’d also like to remove my Carrera badge on the rear deck but assume that will leave residue also.
1) How to safely remove the Carrera badge? I’ve heard using dental floss to “saw” through it works, any better suggestions?
2) How to I get the glue off without damaging the paint?
Thanks!
Thanks,
Chris
1980 Targa, 3.2 upgrade
Old 01-05-2012, 07:00 PM
RETIRED
Joe Bob's Avatar
Goof Off...
2012 ML350 3.0 Turbo Diesel
Old 01-05-2012, 08:46 PM
Rescuer of old cars
Arne2's Avatar
3M Adhesive Remover
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-05-2012, 09:02 PM
I removed many badges before, it's a two step process:
1. Remove badge by using thin plastic rope / thread (dental floss is not strong enough) with "sawing" motion. Do not pull the badge as this may damage surface.
2. Remove glue residue by dab it with kerosene or gasoline (a little amount is safe for paint) then scrape it with plastic scrapper (or credit card).
Lastly polish the paint with compound and wax it off.
Old 01-06-2012, 12:36 AM
cdrik915's Avatar
The better way i found to remove glue residues is White-spirit.
No problem with paint if done without sun shining on and washed after a few minutes.
Also for asphalt residues : apply it and appreciate how it works : the asphalt leaks.
I use that way of doing since many years.
LIGHTER = FASTER !!!
Old 01-06-2012, 02:06 AM
cdrik915's Avatar
Comparing to dedicated products , more expensive , i find "White-spirit" more efficient.
(Sorry , twice)
Old 01-06-2012, 02:08 AM
911oclock's Avatar
Eucalyptus oil will remove the adhesive easily and is gentle on the paint.
Old 01-06-2012, 06:22 AM
mystro's Avatar
Wax will take off residue from decals. I keep a container of cheap wax around like Nu polish just for this purpose.
Old 01-06-2012, 07:55 AM
Flat Six
Flat Six's Avatar
Monofilament fishing line is ideal for this purpose -- thin, long, and sturdy.
Also, heat up the emblem a little w/electric heat gun (on low) or hair dryer (on high) to help soften the adhesive and the Carrera emblem. Don't go so hot you blister the paint, just warm enough and the emblem will come off easily and leave less residue, too.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 01-06-2012, 10:33 AM
Thanks all for the advice!
Chris
Thanks,
Chris
Old 01-06-2012, 11:38 AM
French Import
zippy_gg's Avatar
Is your Carrera badge in good shape? If so can I have it? My cab doesn't have it but can see its outline on the engine lid. You can PM me. Thx!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-06-2012, 12:32 PM
