-   -   Can I extend a wideband sensor wire? (http://forums.pelicanparts.com/porsche-911-technical-forum/648976-can-i-extend-wideband-sensor-wire.html)
Tippy 01-05-2012 09:05 AM
I have the Innovate Motorsports MTX-L AFR gauge and controller.
The cable is about 3ft short of making it to the dash.
Can I cut and splice the wires another 3-4ft from the existing 8ft?
They sell an 18ft cable, but it is $79!
Will this affect the accuracy?
stormcrow 01-05-2012 02:14 PM
Is it a shielded cable? If so you may not be able to extend it. The other issue may be that the wire is designed with a certain amount of resistance in it to make the system work properly.
On the other hand if the wires are just plain 18 or 20 gauge stranded wire I don't think this would be a problem.
TimT 01-05-2012 02:25 PM
Yes
edit: yes you can splice it
no will not affect accuracy
Tippy 01-05-2012 04:00 PM
Thanks all!
ben parrish 01-06-2012 06:17 AM
Yep..did it on mine...trimmed the sheathing on each wire about 1/2 inch..spread the wires and intertwined them...twisted...soldered...heat shrink...then I used a 7' section of heat shrink to make the bundle tidy and easy to route.
Works like a champ.
Tippy 01-06-2012 07:29 AM
Works like a champ.
Did you trim the harness cable or the pigtail coming off of the gauge? Just curious.
The harness has a sheath around it sealed to the connectors. The pigtail from the gauge/controller has seperate wires and seems to be easier to splice into.
ben parrish 01-06-2012 08:08 AM
Spliced between the controller and the O2 sensor. I mounted the controller under the passenger floorboard. Ran the wire along the tunnel, through the grommet in the drivers side rear footwell. Just secured the wire with the existing tabs. I use the Dynojet WBO2.
Tippy 01-06-2012 08:11 AM
Ah, totally different unit. Thanks.
cmcfaul 01-06-2012 11:05 AM
Did it on mine. Spliced the 6 wires to add an additional 6 feet at the rear tunnel access opening. Also fed the connector for the lap top hook up from there. Works like a charm and completely invisible. mounted the gauge to the cigarette lighter hole. Piece of cake.
Chris
Tippy 01-06-2012 12:28 PM
Chris, what brand/model are you using?
