-   -   tail light not working, checked fuse & bulbs (http://forums.pelicanparts.com/porsche-911-technical-forum/649104-tail-light-not-working-checked-fuse-bulbs.html)
torqthrust 01-05-2012 07:00 PM
my left taillight and the engine compartment light is out on my 84. I have checked the fuse, its good plus the front marker light is working. i checked the bulbs and unplugged and replugged the wire connector in the engine compartment a few times. Is there any common issues i should look for before i tear into it?
Joe Bob 01-05-2012 08:47 PM
Look for a corroded brown (Ground) wire in the tail light assembly.
LWJ 01-05-2012 08:51 PM
+1 Ground
Did you put a multimeter on it?
torqthrust 01-05-2012 09:14 PM
i havent yet LW, i didnt have it at my house
paulgtr 01-05-2012 10:55 PM
I had the same problem and it was a matter of the copper connection losing it's tension to press consistently against the base of the tail light bulb. removing the bulb, reaching in and pulling the copper connector toward where the bulb's base will sit fixed the problem temporarily. replacement is in the future as well as cleaning up the ground connections to be safe.
DRACO A5OG 01-05-2012 11:14 PM
After checking with a DVM. consider crack the assembly open to inspect the PCB type board behind the socket. It may have fractured and the contact may have shorted out.
Bending the copper contact may damage the board, so take caution:
http://img.photobucket.com/albums/v5...702_202317.jpg
When you place the back plate on, use some caulk to seal the housing, if not you will get moisture in there.
torqthrust 01-06-2012 09:24 AM
thanks ill check it out
RWebb 01-06-2012 11:24 AM
there is a thread with pics and wire ID that you can search up
shuzboomer 01-07-2012 10:24 PM
I got a similar issue, except I don't have any lights on the left front marker and left tail.
The fuse looks good and the break and turn signals are operational.
Where does one begin?
timchar 01-07-2012 10:35 PM
I had same problem, it was a bad diode, its right behind ignition/key switch. It's about 3 inches long. Just disconnect the diode and reconnect the wires, you don't even need it. Tim
kidrock 01-08-2012 09:47 AM
If Timchar's solution doesn't work, check your light under the engine lid. When the fixture goes bad, it cuts the circuit to the left side front marker light and tail light.
timchar 01-08-2012 09:53 AM
Stone, you're right, probably smarter and easier to check that first. Gotta have small hands to get diode out. Tim
