LinkBack | Thread Tools | Rate Thread |
How to tell if 3.0 SC chain tensioners have upgraded with 3.2 Carrera tensioners?
I am sure there are previous posts on here about this but I cannot find them anywhere.
I want to check to see if my 3.0 SC has had the upgraded 3.2 Carrera chain tensioners fitted to the engine. Is there a quick and easy check that can be carried out to check for this? I believe I have read in the past about checking for the oil feed pipes but cannot remember where these pipes should be located on the engine. Thanks Steve
1978 Porsche 911 SC Coupe. |
Hi steve ,
The simple way is to see if there are hard oil lines going to the chain covers. They will have a banjo fitting on the face of the cover also. Sorry no pics but it is easy to spot. Cheers Nick |
The oil lines that indicate pressure fed tensioners are on the face of the chain box covers easily visible.
Tell it like it is or don't tell it at all. |
Thanks guys.
![]() That was really helpful and like lindy 911 says is a very quick and easy way to check if they have been upgraded in the past. I will check to see if my engine has the solid lines going to the covers in the morning. Thanks again Steve
nice! I think it just moved a little.....
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower ![]() |
