Need Valve adjustment help
Hi
I'm doing my first valve adjustment. I have both intake covers off. While removing the last nut from drivers side cover I notice the stud is spinning. I have not removed the passenger exhaust yet. Should I continue to try to back the stud out or stop now, reassemble & take to a shop?
Old 10-04-2014, 07:29 AM
faverymi's Avatar
No biggie. It may happen to other studs too.
Take the stud with the nut. When out remove nut from stud. When done with everything at the end of valve adjustment clean the stud and the threads with alcohol put some thread lock and put stud back until feels snug(double nut technique works for this). Do not over torque.
Finish putting valve covers.
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 10-04-2014, 07:42 AM
Thanks-
Back to the drivers side then...
Old 10-04-2014, 07:43 AM
Stud is out, just backed out, not sheared. Moving to the passenger side.
Old 10-04-2014, 07:54 AM
LakeCleElum's Avatar
Do as faverymi sez.....Clean up the stud nut......Install the stud with some blue lock-tite. That will ensure it stays behind next time.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-04-2014, 08:11 AM
WilCo on clean & lock-tite the stud.
Thx
Old 10-04-2014, 08:46 AM
OsoMoore's Avatar
Note that, when attaching the valve cover, the nuts on the outside have a fairly low torque spec. Overtightening when re-attaching the valve cover could cause leaks.
They should be about 8 ft/lbs.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 10-04-2014, 08:54 AM
