Accelerator rod bushing
Hello,
I need to installed 3 accelerator rod bushing in the accelerator rod that runs through the tunnel. My problem is that I can't locate when looking inside the tunnel of my '68.
I need to know where are these bushings situated along the rod?
Anyone with experience with these bushings please share your knowledge.
Much thanks,
Bao B. Brand new to forum.
Old 01-11-2012, 04:20 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey Bao,
Okay from the access panel up to pedal cluster:
1st on is under the access panel for the shift coupler on the driver side corner closest to the from. You will see two metal tabs that hold the bushing perfectly.
2nd is under the Shifter, yes you will need to remove the shifter housing. Prior to removing, mark it so you will not lose the position of the shifter and forced to adjust the coupler. Look for the same metal tabs.
3rd one is at the front of the tunnel where the rod is connected to the pedal. You should feel the tabs.
That's it!
After you place the bushing, check throttle body for full throttle position and when at rest it seats properly when at idle. make certain the idle switch clicks when released. Also feel for binding in case your placed the bushings incorrectly. Clean lube all pivots on the rod assembly, at the bell hosing, pedal and TB.
Jim
'85 Carrera Targa
PCA/POC
Old 01-11-2012, 05:35 PM
jhhaas's Avatar
Resurrecting an old thread. I found the one by the access panel. I also found one under where the parking brake lever is located. I do not feel one near the front of the tunnel by the pedals. I have a 1981 SC so I am wondering if anyone might know where that third bushing might go? I hate to undo the shifter if I don't need to. Pelican says there are three, I guess I am trying to confirm it's under the shifter before I proceed. TIA
John H
2001 996 GT3 Cup
1969 911T
2015 Cayman GTS
Old 08-11-2014, 09:04 AM
same question for an 86. can anyone weigh in on this?
Old 10-04-2014, 07:55 AM
The one in the front is part of the pedal cluster. Remove the floor board and accelerator pedal to access. Held in by a cir-clip and can be change w/o removing the cluster.
Randy
1979 911 SC PCA D Class
1998 C2S Coupe, Guards Red, Turbo S Aero Kit.
Old 10-04-2014, 08:58 AM
