factory coating on the inside of the floor boards - what the $#@#! is this stuff?
My car has the original floors still in it. After the rugs and sound deadening were removed - I thought I was looking at metal. However, there appears to be some sort of rubber hard coating about 1/4 " thick. i want to paint the floors......does this mystery coating need to be removed first? What different products/process have people used? Thx.
Old 04-07-2002, 11:11 AM
feelyx's Avatar
I used a propane torch and a putty knife to scrape that crap off. then an asatone bath removed the rest. The (NO SMOKING!!) signs should be posted! ware rubber gloves and a fan running for venting. It removed about 30lbs.
Tim in Sac
Old 04-07-2002, 11:44 AM
CamB's Avatar
I have used a heat gun, and alternatively a low-powered heatgun (also called a hair-dryer , shhhh don't tell anyone), both with a scraper. It should come off before you paint.
If sound damping is important to you it can be replaced when you have repainted. Dynamat works well (but is $$$$). Alternatively generic stuff works fine (eg http://www.mcmaster.com/ - search for damping sheet, then the adhesive stuff - cheapest one is probably similar to what is in the car).
Cam
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 04-07-2002, 01:51 PM
I found that most of this (brittle) coating was removed fairly easily using a (blunt) scraper - it tended to come off in large chunks. Use some gentle heat to soften the last remnants before more scraping - this leaves only minor traces in awkward corners to attack with a suitable solvent (I used white spirit - don't know what name it goes by in the US).
Andy Boyle (UK)
'69 911E
Old 04-08-2002, 02:16 AM
