Electrical connection corrosion...what kinda goo?
Car was a no-start today. Had been sitting for some time, but started up and ran for a few days last week.
Today...no start. Engine cranked, spark produced, no fuel...something sounded suspiciously quiet. Fuel pump wasn't whirring. I put the car on the lift and checked the connections to the fuel pump. They were slightly corroded, but not bad. My car hasn't seen so much as a puddle in six years & is stored in a climate-controlled shop. Once I cleaned the connections, whirrrrr/vrooommm. Started right up. So, question is: Is there something I can put inside the rubber boots covering the fuel-pump terminals to prevent corrosion? Silicone grease? |
Use dielectric grease. You can get it at almost any FLAPS.
Somatic Negative Optimist
Usually neglected: Hidden negative battery connection to the body inner fender. Open and clean connectors, bolt and body area then use dielectric grease. My favorite other items: Any other connectors like 14-pin, 6-pin CIS, 6-pin CDI in short; All connectors especially ground.
Even Vaseline is better than nothing. Enjoy.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
ROW '78 911 Targa
If you can find it use NO-OX ID. We use it on commercial battery connections. It's a very good corrosion inhibitor for electrical connections. Or just use battery post grease from a parts store.
