911 sc: ignition switch on and the starter randomly engages???????? this is scary.
I tried searching for this, but no luck. Just installed an engine into an 82 911sc.
With the ignition switch on, the starter will randomly and every second engage the starter for one quick second and then does it on and off.
recommendations?
thanks in advance
Marlin
Marlin Ness
sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8
currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera
Old 01-14-2012, 03:38 PM
83 911 Production Cab #10
JJ 911SC's Avatar
recommendations?
thanks in advance
Marlin
Which engine, 3.0 or 3.2?
Who Will Live... Will See
Old 01-14-2012, 04:08 PM
81 SC 3.0 into an 82 SC body.
I originally thought it was the key ignition switch. But, the starter was turning on without touching the key once I turned it to the on position. On and off, on and off almost like a relay was slowly cycling. very strange indeed. Just got a Bentley manual today and will start looking. Also, although it started and ran, I had a fuel leak. After I fixed the leak, it didn't start anymore and looks like the fuel pump is gone. No noise even when connected directly to the battery.
Marlin Ness
Old 01-14-2012, 08:22 PM
If the car originally had A/C (most), check the little metal relay in the smugglers box, it can cause this symptom.
Paul
Old 01-15-2012, 06:57 AM
Check the insulation of the wires at the starter. If the insulation is worn on the yellow wire and the battery cable then if they touch the starter will engage. This short bypasses the ignition switch.
69 911 2.3Ez
85 928S
Old 01-15-2012, 07:30 AM
